Old 02-25-2002, 12:43 AM
YK86 YK86 is offline
Send a message via ICQ to YK86 Send a message via AIM to YK86
Any good sites for indepth specs on internal parts??
Hi. I'm trying to gather info on Honda engine internal parts (rod length and wrist pin hole sizes, compression ratio, and piston diameter and wrist pin hole sizes). I'm mainly focused on B series, and H22/23. I only have bits and pieces since most sites only list bore and stroke but no stuff on wrist pins. Thanks in advance.
Member since October 5, 2000
Old 02-25-2002, 01:06 PM
Rgacke's Avatar
Rgacke Rgacke is offline
wouldn't a good manuel give measurments? (I'm talking about the manuels that mechanics use)
"shut the door Joshua, and let death pass by..."
Old 02-25-2002, 07:22 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
ugh... attempt #2 to reply, the first one vanished into cyberspace
I have some of the info you're looking for (from helm manual)
the following info is for the B16A2 engine, specs from 1996-2000 manual
all units are mm unless otherwise indicated
piston skirt OD measured @ 15mm from bottom: 80.980-80.990
piston pin OD: 20.994-21.000
pin to piston clearance: .010-.022
pin to rod interference: .013-.032
SE bore diam: 20.968-20.981
BE bore diam: 48.0 nom
crank pin diam: 44.976-45.000
bore: 81.0
stroke: 77.4
compression ratio: 10.2
sorry, I don't have the centers length for the conrod.
Old 02-26-2002, 03:43 AM
Thanks! That's exactly the type of specs I'm looking for. If anyone has anymore B-series or H22/23, that would be great!
Old 02-27-2002, 08:18 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
I have the perfect site for you.
http://raceseek.com/honda_specs.htm
Enjoy.
Old 02-28-2002, 02:53 AM
Perfect! Thanks alot!
any good sites for 88 z24 performance IRideAFly Cavalier 0 04-23-2005 10:21 PM
post good sites for car specs and 1/4 times. GT500916 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 10-04-2004 05:37 PM
looking for a good site for subbox specs whatcha/got/racer Car Audio 4 09-01-2004 08:50 PM
Any good sites for WRC interior/ reference photos? flyingmachine Car Modeling 3 12-06-2002 04:50 AM
Any good site for 2001 or 2002 z24 Evil_potato Cavalier 3 10-02-2001 08:57 PM
