Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 02-24-2002, 06:24 PM
paradyme paradyme is offline
Question 911! How Do You Remove a EGR Solenoid Valve????
Hey everyone I'm trying to remove then replace the EGR solenoid valve, it has a male to femele plastic connector and I can't seem to find where it needs to be depressed. The solenoid valve is located on the back side of the engine near the fire wall and is hard to get at. I have so far been able to remove the screw that holds it to a mounting bracket. Now all that holds it to the engine is the three short hoses that are attacthed to the selonoid valve and the connector I have mentioned. If anyone out there knows of a way to remove this please chime in. Your assistance would be Greatly Appreciated!!!!!!!!! :flash:
paradyme
95'G20t/AUTO/BLK
STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/
VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO
Old 02-24-2002, 09:25 PM
CanadianG's Avatar
CanadianG CanadianG is offline
Send a message via ICQ to CanadianG Send a message via Yahoo to CanadianG
You are in luck
I did mine yesterday. Step by step instructions here" http://www.se-r.net/car_info/problems/index.html " or here " http://www.se-r.net/faq/problems.html if you have anymore questions just ask.
Women call my bedroom the COCKpit!
Old 02-25-2002, 12:12 AM
I'm not talking about the EGR or the BPT valve. I'm referring to the EGR solenoid valve. I'm very familiar with SE-R.net and it's many articles. None that I know of refer to the EGR solenoid valve. Thanks for the suggestion anyway.
:flash:
paradyme
95'G20t/AUTO/BLK
Old 03-18-2002, 09:58 PM
GtRider GtRider is offline
Send a message via AIM to GtRider
i have that same problem!
does anyone have any pics of what the EGR solenoid valve lookz like?
and about how much does it cost ?
94 G20t
Old 03-19-2002, 07:28 PM
Lightbulb
I managed to replace mine. 1st you need some light so you can see what you are doing. 2nd remove the 3 rubber hoses and bracket screw.
This will allow for you to handle the valve. The vavle is held to a wired connector or harness, What you need to do is find or use a tool with a very sharp point ie, small ice pic. This is because there is a very thin metal clip that is attached to the base of the female connector that holds the solenoid valve in place. Pry the clip which is square in size with pointed tool mentioned then depress the little tabs that protrude on each side of the female connector. It should release, also replace the black hoses just to be on the safe side. reconnect the valve to the mounting bracket attached the hoses and your done. the part number is #14956-58C10 There are two solenoid valves that were made for the SR20DE engine. the part number mentioned is for your car make and year model
this is the other part #14956-38U10 produced for cars made after July 95. You can get the part from www.nissanparts.cc $58.00 or try Scottsdale Infiniti, Ask for Ralph or Joe.
:flash:
paradyme
95'G20t/AUTO/BLK
Old 03-21-2002, 11:00 AM
where exactly is the egr solenoid valve on our engines?
94 G20t
Old 03-31-2002, 10:29 PM
ronnie_g's Avatar
ronnie_g ronnie_g is offline
Wink
Yeah! Please post the picture just in case I need to change mine soon.
94'G20t / UR Ultra S pulley / JWT Pop charger .....
Sony ES Head/Boston Acoustic Pro Series 6.4/ Cerwin Vega 6002/
MTX 3x10's/ Monster Cap
Sony XE-90MkII EQ/ SonyCDX715
CD Changer/Nakamichi EC-302
Mobile 3-Way Electronic X-over
Amps: Fosgate Punch 600w A4/ Kenwood PS300/JBL GTQ360
Protection: G19 15+1 Cor Bon +P 115 GR JHP/Bali
:jump: :badass:
Old 04-16-2002, 08:01 AM
what happened to the pictures?
94 G20t
Old 04-16-2002, 08:55 AM
ronnie_g's Avatar
I took a picture of the EGR valve before but didn't came out clear. It was in the freakin hard to reach spot behind the engine. There are so much shitski to remove before you get to it. You can see the BPT clearly but the EGR is hiding and very shy I hope someone else with a great camera will provide us with the clear picture of that freakin' EGR valve.
Good Luck!!! :toothless
:jump: :badass:
How to replace fuel solenoid/valve? guitarfish Grand Prix 2 03-10-2010 05:32 PM
How do you remove the spoiler from the hatch? Sonic Eclipse Exterior and Wheels 3 10-08-2009 10:35 PM
95 Intrepid EGR Valve apmavis Intrepid 0 07-23-2009 05:20 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
1995 Grand Prix Check Engine Light EGR Solenoid Valve NightTime Grand Prix 1 06-19-2005 05:18 PM
