Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-24-2002, 05:48 PM
BigB BigB is offline
Question Nology Hot wires
I was going to upgrade my wires and plugs and i decided on NGK plugs because they seem to be a pretty good plug with everyone. But i'm not sure about which wire to go with. What is the deal with these Nology hot wires (300 times more spark?) Also they are very expensive, much more than any other brand. Are they worth the cash? Which wire is a good choice?
Old 02-24-2002, 07:32 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
there's no proven hp increase with the Nology HotWires. the external grounding strap is what causes the spark to look brighter in the examples... but it doesnt increase voltage or truly make a hotter spark. just merely a "distorted" spark that looks big, but burns no hotter than any other spark from the competitors' wires.
personally, i use Magnecor wires... but then again, i have a turbocharged Prelude
Old 02-27-2002, 12:48 PM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
How much gas would I safe by using a better ignition system?
Old 02-27-2002, 07:44 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
As long as your stock system is in good condition: just about NONE. No hp increase either. If you use N2O or forced induction, it might require a mild upgrade. But on the other hand, as drift likes to point out, the Apexi drag Integra, with twin turbos, runnning the 1/4 in the eights and 155+mph -- uses the OEM H22A ignition system.
The Honda OEM ignition is one of the best systems out there.
Old 02-27-2002, 08:21 PM
Veetec's Avatar
Good to know that. Thanx for your reply!
nology hot wires arodg25 '88 - '91 Civic | CRX | Wagon | Shuttlee 10 05-10-2007 11:06 PM
Nology Hot Wires? Epower87 Off-Topic 15 04-22-2004 10:32 AM
Nology Hot Wires frozen_Joth '88 - '91 Civic | CRX | Wagon | Shuttlee 12 06-18-2003 08:59 AM
Nology Hot Wires so-cali Engineering/ Technical 10 07-31-2002 01:39 PM
Nology hot wires for sale Celica GT Kerpalstaxi Celica 0 01-17-2002 04:45 PM
