Old 11-13-2004, 02:07 PM
marcus319 marcus319 is offline
hood won't open! any ideas on how 2 open?
cable is taught and seems fine from the interior hood release handle into the front of the car
Any idea on how I can open the hood if the hood release is not working would be GREATLY appreciated or what I can do with the cable too try and make it work.
It seems like a simple cable.
Thank you!
Old 11-13-2004, 05:16 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
maby try pulling the handle on the inside, the pounding the front of the hood once, it might pop open...
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 11-13-2004, 05:44 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: hood won't open! any ideas on how 2 open?
had the same problem with my truck when I first got her... have someone sit in the car holding the hood pop latch out/pulled. Then you go up to the front and try to get your fingers/something in between the hood and the bumper. A few thumps may be required. If this is a suddenly occuring problem, check your cable from the interior latch to the hood latch. Also, with someone holding the latch to the open position, lower the hood slowly into the latch, making sure everything is lining up. Luckily, hood latches are way easy to replace. If the problem has been around for a while, check the rubber stoppers/springs in the latch for wear and tear. Good luck.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 11-13-2004, 05:54 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Same thing happened to my rent's minivan. I had to tug on the cable with a pair of plyers while my dad hit the edge of the hood until it popped. It ended up being just a slightly rusted latch, and some WD-40 fixed the problem from happening again.
Here's a useless fact about WD-40 that has nothing to do with this topic. WD-40 was named that because it was the 40th attempt to get the right mixture to do the job. Yes, I'm a
Old 11-13-2004, 06:20 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Interesting fact there, you learn something new everyday, lol.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 11-13-2004, 06:26 PM
thanks so much for the ideas. Tried the plyers but didn't have anyone up front working the hood. Sounds like a good way to work out any pent up aggression as well !
Thanks again!
