Old 11-10-2004, 03:23 PM
Boosted1 Boosted1 is offline
Question Loose steering...
My dad has an '89 5.0L Mustang notch, lightly modded, and the steering is becoming increasingly loose. Does anyone know how to fix this? I assume only by purchasing a new steering column, and if that's the case, where can I find one?
Old 11-10-2004, 03:37 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Steering lose...... you need to elaborate more. Also that so does not mean you need a new steering column necessarily.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 11-10-2004, 03:40 PM
The car is all over the road, it wobbles, and can't go in a straight line, especially at highway speeds.
Old 11-10-2004, 07:20 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: Loose steering...
Try getting the alignment fixed.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 11-10-2004, 10:22 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
It could be so many things. Check your tie rod ends, ball joints, etc. Also check your tires for chopping and abnormal wear. An alignment would probably help a lot as well.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 11-11-2004, 01:46 PM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
yeah check tire balance too
Old 11-14-2004, 01:14 AM
gmartinez gmartinez is offline
how is your suspension?
rebuilding my 86 LX??
Old 11-14-2004, 04:19 PM
The more I read the replies, the more it seems like it could be a million things. The suspension is a good thought, it squeaks and groans, especially in cold weather. He's planning on dropping it an inch and a half in the spring. We just got snow the other day, so it's gone for the winter.
Old 11-14-2004, 05:27 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
the rag joint in the middle of the steering shaft often breaks. it's broken in my '86 notch. and that car did the same thing while it was running. look at the big part of the steering shaft (right next to the driver's side header) and see if it's ripped. wiggle it and see if it turns independantly of the steering rack a few degrees.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 11-14-2004, 10:05 PM
Re: Re: Loose steering...
fine. how about yours??
Old 11-14-2004, 10:47 PM
Re: Re: Re: Loose steering...
hehe, sorry, it was for boosted1
(anyway, mine is not so good now)
