Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 11-09-2004, 03:26 PM
mustangfreak145 mustangfreak145 is offline
stroker with blower?
ok i was wondering is it good to use a stroker kit with twin turbos or superchargers? i also heard that if you bored the block your not supossed to use forced induction because of the compression is this also true? thanks
Old 11-09-2004, 06:39 PM
Ghost96Gt Ghost96Gt is offline
Send a message via MSN to Ghost96Gt
Re: stroker with blower?
well alot of people used FI on a stroker so u will be fine just make sure u design the kit for FI.
Old 11-09-2004, 09:01 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Whoever told you that doesnt even have a clue what hes talking about. In general, an overbored block is better than stock for FI. Due to the fact that compression ratio would be lower with the same heads and crank yet. Using FI is perfectly fine on any motor, considering it is built with strong internals.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 11-09-2004, 09:17 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
FI on a stroker is fine as long as you respect the rules of basic engine building 101.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 11-10-2004, 04:14 PM
i guess i should not take there word on anything anymore. thanks for not slamming me about the question. it sounds kinna lame but thats why this site is here is to ask questions right? and not blow up anything.how much is to much of a bore is to much
Old 11-10-2004, 07:07 PM
GTStang's Avatar
Stang Guy
How much bore is too much really depends on the block. They only true way to tell how good a block is, is to have it sonic tested for cylinder wall thickness etcc., Not all blocks that are the same are casted exactly the same. One 1987 302 could be bored .60 and have plenty of wall thickness left while another 87 302 casted at the foundry right after at only .30 could be a lil thin.
Or without sonic testing you can have a good general idea of the block style as the difference between 70 302 casting and a 87 302 casting and know what the general consensus is.
Old 11-21-2004, 05:11 AM
NIN881 NIN881 is offline
A stroker is a different crankshaft. You don't have to bore it out, but most of them are. both 347 and 331 are. The standard it boring the 302 to a 306.
1994 Mustang GT, TFS TW heads, TFS street heat intake, Pro 5.0 shifter, BBK LT headers, BBK short off road H, Mangnaflow catback, FMS 3.55 gears, TFS 1.6 rr, JMS chip (soon to be replaced by a tweecer).
Horsepower sells cars, torque wins races.
