| Cosmetics interior, exterior, wheels. |
just ordered the factory foglight kit for my 2002 G20
Just to prepare myself. how hard is the installation? To me it looks like you just remove the template cover from the bumper and the harnesses are right there? Plug em in and bolt on the foglights? my main question is are there any other types of wiring that I have to do to set this up? Is it complicated? input is appreciated. thanks !
Nope you pretty much got it. Wiring is all there, just plug and play. Dont forget to install the column switch too...and the relay...and the trim pieces...good luck, youll get it.
P@ - www.customsteel.com Red 99 G20(t) / UR 2 piece / JWT POP / HS CAI / WW Lip / HS Header / Greddy Evo / S3 cams |
thanx guy. I read a few post on the message board that most of you guys "re-wired" your foglights? I'm not too clear on this? So, pretty much if you do this modification all it's doing it keeping the foglights in use when using your high beams as well as when you use the lowbeam?
if I don't want to "re-wire" my fogs, it will only work w/ the lowbeam? That's what i'm gonna be using 99% of the time anway right? I don't use the highbeam too often, so i wouldn't need to do this modification?? correct?
Do it if you want, Its all personal opinion.
