Old 02-22-2002, 12:21 AM
mikami mikami is offline
INTERIOR (cheap)
k.... i just bought a 91 acura integra... the guy did the interior with that paint stuff... all of it is chipping off and it looks like shit...
i need to know how to remove it.. the paint
and what are the best steps to get the best results from self painting ur interior.
do i need to sand? prep? someone help me out.. thx
Old 02-22-2002, 02:26 AM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
you don't need to sand. But you need to primer, then maybe 1 or 2 coats of paint, then a clear coat would look nice. I suggest you just try to paint on top of what he already has.
AF Nordic Crew #3
Old 02-22-2002, 05:12 AM
NEED4SPEED NEED4SPEED is offline
do what buh buh wrote and make sure the primer is for the right application. But, i would reccommend that you not paint over the existing paint. If you want to do a good quality job and save yourself sometime l8ter on, remove it all and start from scratch. If you dont start from scratch the original paint will come to the surface of your new paint crack it and create uneven surfaces, which i assume you dont want.
Old 02-22-2002, 06:27 AM
igo4bmx's Avatar
igo4bmx igo4bmx is offline
Banned
Send a message via AIM to igo4bmx
if its chipping, sand it all down and restart!
Old 02-22-2002, 01:30 PM
xivera's Avatar
xivera xivera is offline
Isn't there a solution that will remove paint?
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 10-10-2003, 12:59 PM
EliteConcepts's Avatar
EliteConcepts EliteConcepts is offline
Banned
Send a message via AIM to EliteConcepts Send a message via Yahoo to EliteConcepts
Exclamation Interior
Ok, First off you want to remove all the old paint.. If you paint over that it will continue to chip. Chiping is caused by lack of bond between the surface and the paint... I do custom interior for a living so here are the right tips..
remove all the old paint..sand all the surfaces that need to be painted... If you want to make your interior show quality then you need to resin all panels. resin is a fiberglass layer that is hard and sands really smooth... then get a actual paint gun... use automotive paint... and get the automotive clear.. go with 3 layers of base and about 5 layers of clear..
get single stage base paint..
Elite Concepts
Old 10-10-2003, 01:05 PM
T!mmy T!mmy is offline
Send a message via AIM to T!mmy Send a message via MSN to T!mmy
Re: Interior
Elite Concepts
Quick question...I'm doing this (well I'm doing a complete glass interior but anyways) if you put resin over it what is the purpose of sanding it?? I doubt the resin will flake off lol. Not being an ass just trying to learn so that whenever I do this I'll know
EDIT: I mena why sand before you put down the resin...
The Dr. tells me too much masturbation is unhealthy...So when is "too much" masturbation "too much"???
Check out our car club site which I made http://www.almostperfectcc.com
Originally Posted by 18c5sol94
we go from a stop he pulls a little on me (only cause i can't keep the wheels on the ground)
Old 10-10-2003, 05:25 PM
Banned
ok glassing it was the second option... there were two ways to do it that i posted it was sand it and if you want show quality you CAN glass it then i continued with how to paint it.. i just left out some words there to define what way i was talking about.. Sorry about that.. but its still a good idea to sand first.. the only reason you would glass it to make the surface hard, meaning it was vinyl.. and some vinyl protectors like to soke in a bit to the vinyl.. glass still has to have a solid surface to stick to. some cleaners and shit wont take that out so you have to sand off some layers to get a good glass bond.. another way , the way mine is done is epoxy.. epoxy is extremly hard to do but its alot lighter than glass.. i do not recomend doing it unless your town has a company that can dip it..that way you get a real fine layer of it on there....
Elite Concepts
2003 Venture Interior Lights OnThePike Venture 16 12-03-2010 12:39 PM
98 Olds electrical - interior lights turn off 63johnm Silhouette 0 07-12-2010 12:32 PM
Interior design question kinda.loopy88 Non-Performance 0 04-19-2010 01:13 AM
Cheap HP (and i mean cheap) housy_bigmike Camaro Discussions 13 03-07-2004 12:00 AM
