Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 10-20-2004, 06:01 PM
bigbob bigbob is offline
14 psi = kaboom?
stock 95gt, can the internals handel 14 psi? not every day driven and if they blow up on me it giev me an excuse to stroke it. will it take 14 psi
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 10-20-2004, 06:13 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i've never seen a supercharger kit for a stock mustang motor that's designed for more than 9. i believe that 14 would eventually blow it up.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 10-20-2004, 07:45 PM
Re: 14 psi = kaboom?
im not gunna buy a kit im thinking i want a kenne bell supercharger, and u can buy them with a number of different pullies. and ill get 42lbs injectors 225l/hr fule pump, new throttle bod/mass air meter and basically build the kit my self.
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 10-20-2004, 08:59 PM
Ghost96Gt Ghost96Gt is offline
Send a message via MSN to Ghost96Gt
yeah i think it will go bomb 14 psi you will have around 580 to 610 hp thats alot on stock internals, but not postive
Old 10-21-2004, 02:01 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Stock 302 blocks are really only reliable at 10psi with some type of air charge cooling. After that your playing bad odds.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 10-22-2004, 12:33 AM
ToplessNSeattle ToplessNSeattle is offline
That's funny shit.
Pat
03 Black Mustang Cobra Vert
Performance Chip
2.81" Pulley
Cold Air Intake
FloPro V-Force Mufflers
Shock Tower Brace
Sub-frame Braces
T-5 Shifter
WFO 'til you see God, then brake...
Old 10-22-2004, 12:55 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
intercooler and alcohol injection. When I get out of college this may and get some money saved up, I plan to figure out for myself how much boost a stock 302 can hold. I think as long as you are not pre deat. you should be fine. Im not for sure though. I will have to do it myself and see.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 10-22-2004, 10:15 AM
GTStang's Avatar
Stang Guy
I can already answer ya questions Hypsi.... as much boost without pre deat as you can pump in it until you make 500+HP cause your gonna crack the main webbing.
TT 5.0 guys have been making ~500hp on low intercooled boost levels(~10psi) on stock block, stock internal 5.0's. Once you climb over 500HP your main webbing is your restriction.
Intercooled S/C guys make the 500hp mark around 14psi and then run into the main webbing issues also.
Old 10-22-2004, 07:08 PM
NIN881 NIN881 is offline
can you get something to support it or are you stuck buying a dart block?
Old 10-22-2004, 08:29 PM
boosted331 boosted331 is offline
Re: Re: 14 psi = kaboom?
A Mexican/B50 block is a great alternative. I didn't belive how strong they were after I cracked a Mexi block at about 550 RWHP with nitrous, but this summer a friend of mine broke the 9's on a mexican block 306 running an eagle crank/rods and SRP pistons, some trick flow's, a blow-thru 650 holley on a weiand xcelerator, and twin TO4E 60 trim's. Keeps the RPM's down to about 6300 at the shifts, and traps 138.
I think there was a flaw in my mexi block that caused it to crack at 550 RWHP. I would feel comfortable with a mexican or B50 block to around 650-700-ISH RWHP.
Old 10-23-2004, 12:16 PM
What about a DSS block CNC 20 they can hold 750 hp.
Old 10-23-2004, 02:43 PM
Those are a retarded waste of money, they would never hold 750 HP. They're a stock, weak mains, thin wall block with some material removed. Isn't going to do shit to make up for the fact that stock blocks are weak. Go look at the bottom end of one some day, the main bolts are barely even tied into the main caps, they had to put a semicircle of extra metal along the edge of the main cap for the bolt to have atleast SOME meat to grab into. The stock blocks are inherently weak with lots of flaws, and CNC machning them down is not going to do anything.
Old 10-23-2004, 09:12 PM
Did not no that at all i just read mm&ff and they used one to build there 331 stroker project (331 ways to waste a ls1)
Old 10-27-2004, 05:38 PM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
in the 5.0 & sf they had a stock moter besides S/C making 14pounds of boost and he ran mid 10s.
