Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 10-18-2004, 02:48 PM   #1
jando G
EGR valve and wiper motor placement
Hello,
I am wondering if someone could help me with two quick questions.
1. I need to clean the carbon from my EGR valve and install a Kleen Screen EGR Gasket. Where is the EGR valve located?
2. Where is the 'wiper motor circuit board' located? I have a replacement and just need a little direction.
Thanks in advance to all that reply. Your help is greatly appreciated.
Jando G
jando G is offline   Reply With Quote
Old 10-18-2004, 06:30 PM   #2
Trail Blazin96
Send a message via Yahoo to Trail Blazin96
Re: EGR valve and wiper motor placement
jando what year is your blazer???
Trail Blazin96 is offline   Reply With Quote
Old 10-18-2004, 07:59 PM   #3
BlazerLT
AF -Advisor
BlazerLT's Avatar
Tell us your year.
Also, don't install the gasket, you WANT to get the carbon out of your engine, not trap it in there.
BlazerLT is offline   Reply With Quote
Old 10-18-2004, 08:45 PM   #4
OldieButGoodie92
Send a message via AIM to OldieButGoodie92 Send a message via Yahoo to OldieButGoodie92
I dont know alot but i do know if u have a 90-95 vortec ur egr valve is under ur intake kinda in the back http://www.partsamerica.com/PartDeta...pe=282&PTSet=A Hope this helps.
OldieButGoodie92 is offline   Reply With Quote
Old 10-18-2004, 09:49 PM   #5
barpat96
barpat96's Avatar
The wiper motor may be under a recall. I had mine replaced earlier this year on a 97 blazer.
barpat96 is offline   Reply With Quote
Old 10-19-2004, 07:59 AM   #6
jando G
It's 1998.
ok, I won't install the gasket.
I still want to clean it out though. So the EGR valve is under the intake. So where is the intake? I am out of my element as soon as I open the hood.
I don't believe '98s are covered in that wiper motor circuit board recall but I could be wrong.
Do you know where it is located so I can replace it?
Thanks for your replies.
Old 10-19-2004, 11:35 AM   #7
powering
The pulse wiper motor circuit board is on the wiper motor body itself, but is taken off separate. Open hood, locate wiper motor. Unplug the electrical socket, undo the screws in the face plate and CAREFULLY pry plate away from body. It will stick a bit as they use a black silicone to prevent moisture.
Quite easy to do, I had to be a little more carful with mine as I was too cheap to buy a new one and just cleaned it up and used the solder fix (resoldered five connectors on back of board). Been 6 months now and still works great. Knock on wood!
powering is offline   Reply With Quote
Old 10-21-2004, 08:13 AM   #8
jando G
Thanks everyone.
Old 10-21-2004, 12:59 PM   #9
mike2004tct
mike2004tct's Avatar
Originally Posted by powering
....I was too cheap to buy a new one and just cleaned it up and used the solder fix (resoldered five connectors on back of board). Been 6 months now and still works great. Knock on wood!
Talk about cheap, I was going to keep my old one for a spare,but NAPA wanted it for the core when I bought a new one for $25.00.
The core value ???? $0.50. Ha.. 50 cents.
Before buying the new unit, I did inspect all solder joints, and I didn't see any bad joints , I work with circuit boards for a living, so I consider myself capable of finding bad solder joints.
(I was under the impression there were some bad joints on the axial leaded capacitors that are bent over to fit inside the motor housing,which led to broken or intermittant contact on the leads)
mike2004tct is offline   Reply With Quote
