Old 10-13-2004, 07:48 PM
MIKE! MIKE! is offline
Send a message via AIM to MIKE!
NewRIms...speedometer addjstment
ok so how do i addjust the speedometer from sittin on 15'' to 17'' rims on a 96 accord?
96 Two door accord (pimpin the white)
3'' cold air intake K&N filter
carbon fiber altezzas (girls think altezzas are pretty...whats your excuse)
lookin on gettin a skunk 2 exhuast system....pay checks a commin
Old 10-13-2004, 08:02 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
Rim size isn't much of an issue...the issue is the diameter of the tire.
I disregard my perceived image in the persuit of knowledge.
Old 10-13-2004, 09:47 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: NewRIms...speedometer addjstment
if you get the right size tire there should be no need to change it.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 10-13-2004, 10:07 PM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
do a percentage calculation on the difference of the circumfirance of the tires. If it differs by say 10%, then your speedometer will be off by roughly 10%
Old 10-13-2004, 10:26 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
If you need to correct it, there are ways. Yours is probably one of two possibilities. Either the computer needs to be reprogrammed or there are DIP switches somwhere either in the computer or the dash. Sometimes there are little coded plugs, but its not common.
Head over to the accord forum and someone there might know.
Dragging people kicking and screaming into the enlightenment.
Old 10-14-2004, 12:23 AM
Kven's Avatar
Kven Kven is offline
i dunno how to do it but; nobody answered his question, and my(CRX) has a mechanical speedometer(actual cable going to differential)so i dont think it runs off any electronic switches(dont know for sure though); just thought i might add that in.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 10-14-2004, 05:59 PM
curtis73's Avatar
The 96 Accord should be all electronic. In 96 it switched to VSS (vehicle speed sensors) to go along with OBD2. It can use that signal to drive a speedo, so there is no reason for the cable. Not saying it can't be a cable, just no reason for the double engineering. Let's just say that I've never seen a 96 or newer vehicle with a cable speedo, but they could be out there.
Old 10-17-2004, 11:30 PM
383PhoenixAm's Avatar
383PhoenixAm 383PhoenixAm is offline
Send a message via AIM to 383PhoenixAm Send a message via MSN to 383PhoenixAm
I'm not sure if this applies to import cars, but on cars with mechanical speedometers, the speedometer is driven by a gear in the [transmission?]
Changing the ratio for that gear recalibrates speedometer. its selected by tire size and differential gear ratio.
This is completely subjective, of course. It probably doesn't apply to Hondas. The dealer would know.
