Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 10-11-2004, 11:34 AM
bigbob bigbob is offline
and then there was heads
hey fellas, lookin at heads, more specifically the afr's. can u guys school me on the pros and cons of the diff sizes {165cc, 185cc, etc} and what will be best bet for supercharged setup.
Old 10-11-2004, 12:53 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
lots of people use trick flow twisted wedge heads, they have good flow numbers and tend to make nice power right out of the box, and cost half of what afrs will cost you. summit racing has a package that includes those heads, the street intake, a timing chain, and a cam tailored to all of it. also has pushrods and double-roller rockers. costs about 2 grand, which is what AFRs will cost. it made almost 400 horse on a 306 with a TB, MAF sensor, and underdrives. not sure how it is with a supercharger, but i'm sure it makes crazy power.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 10-11-2004, 01:54 PM
Re: and then there was heads
thanks abunch ill look into it
Old 10-11-2004, 05:32 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
AFR 165 and 185's do not cost $2000 hell the AFR 225's I used don't even cost $2,000. So now way twisted wedge's at $1,100-1,200 cost half!
AFR's heads win in every class when compared to something in the same class. I think 165's,185's average $100-200 more than twisted wedge heads.
Not like TFS are a bad choice but let's get out facts striaght guys.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 10-11-2004, 06:10 PM
on afrs web page it says u need dished pistons to make room for the valves is that true in every case? cuz i want to keep my stock ones in there for now.
Old 10-11-2004, 10:46 PM
i believe you can use stock pistons with the tfs heads.
gtstang: sorry about the mixup, i thought that was what i saw when i was pricing heads a good whie back.
-Andy
Old 10-12-2004, 02:10 AM
motor_head_429 motor_head_429 is offline
AFR 165s are the best for a mostly stock car. 185s for a stroker (331, 347 etc.). 205s probably for a stroker that sees mostly high RPM. 225s, well, I wouldn't even think about using 225s on the street. Twisted Wedge heads have larger runners than the AFR heads (165 vs 170) and larger valves (1.90 vs 2.02), so the AFR heads are going to give you better low end torque. They also flow a little bit better than Twisted Wedge heads so you're going to have a better top end.Twisted Wedge heads also have larger combustion chambers than the AFR heads, so they will not generate as much compression. With the Twisted Wedge heads your compression should go down to about 8.88, with AFR heads, your compression should get up to about 9.35:1. I actually want to get 165s for my Cobra.
By the way, you CAN use Twisted Wedge heads with stock pistons with up to .540 valve lift, but only on 1986 and newer models. Don't quote me on it, but I'm pretty sure I'm right. You might want to look at the Trick Flow website to get more details.
Old 10-12-2004, 12:32 PM
GTStang's Avatar
Stang Guy
185's are good for stroker 302's and stroker 302's with a lil psi action.
205's are good for very high psi 302 block set-ups, very high rpm stroker 302's and a mild stroker 351W
225's are good for 351W strokers if yo want it to breathe at all in the upper RPM range, and some small stroke 351W strokers with some psi.
Old 10-14-2004, 08:37 AM
burly94gt burly94gt is offline
i just this past week purchased a pair of TFS heads that have been milled to 58cc's and had a valve job 100 miles ago for $850... gotta steal!! hte milling and porting alone were $750
The rule of thumb is you can go up to .540" lift so long as you do not go
any narrower than 112* LSA & no more than 224* @ .050" duration.
This is just a generality, you must verify the piston to valve clearance to
know for sure...
actually the trickflows flow better on the intake side and the 165's beat TFS slightly on the ex. side....to me the heads are almost equal, only afr's are a little better quality.
hear are some flow numbers from ford muscle for ya... look under "Choosing a New Head" to see what the "green machine" did w/ a stock cam... http://www.fordmuscle.com/archives/2...r/index2.shtml
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 10-19-2004, 10:58 PM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
AFR's all the way in all the comps they make the most power.
Old 10-31-2004, 08:25 AM
eillob's Avatar
eillob eillob is offline
Yes AFR heads are definaely the best head, course your gonna pay for the best. about $1,250 to 1,300. AFR actually has a newer verion of the AFR165 available that flows even more, runs about $1,600 bucks.
Don't forget about the other heads available you don't have to have AFR's to make good hp. Check out this flow chart
http://home.isoa.net/~mharrisj/fordhead.html
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
