hi i got a 1998 expedition from use car dealer. he done have the Keyless Entry code so i can use the touch pad to enter the driver side.
Dose anyone know how to reprogram it? Keyless Entry code pad on driver side.... |
Re: Keyless Entry help with programing touch pad code
I just found the instructions for this.. it worked on my 99....
see my post http://www.automotiveforums.com/vbul...d.php?t=299771 |
2000 expedition
Need help to find the location of computer module to get code that is taped to it for the keyless entry pad.
Re: 2000 expedition
you can also find it in the above link. Here it is (I have cut and paste). If it's on the computer module, you need to look under the dash on the driver's side. You'll se what looks like a mulit-pron plug in there. It should be black. This will either be right under the steering wheel, or it will be off to one side. If you still can't find it, roll it over to your Ford dealer and ask them if they can find it based on the VIN number or if they'll hook it up to the computer and tell you for no charge. Hope that helps! |
Re: 2000 expedition
look up under the dash...you will see a box with a large black number printed across the middle..that is the factory code..you will not be able to change that code but you will be able to add more codes...
