Can you change the keypad code?
I can't remember mine. I have to get out my code card everytime. Is it possible to change the code to make it easier for me to remember?
Re: Can you change the keypad code?
I found the instruction. you can't change the code, but you can add another code.
Programming your own personal entry code Enter the factory-set code (keypad will illuminate when first digit is pressed). Press the 1/2 control. Enter your personal 5-digit code. Your personal code does not replace the factory-set code. You can use either code to unlock your vehicle. Each time you set a new personal code the module will erase the previous one in favor of the new code. Deprogramming (erasing) your own personal code and leaving only the factory-set Enter the factory-set code. Press the 1/2 control. Press the 7/8 and 9/0 controls at the same time. The system will now only respond to the factory-set code. Unlocking the driver's door (also disarms the perimeter alarm system) Enter either the factory-set code or the personal code. The interior lights will illuminate as soon as the first valid digit is pressed. Unlocking all doors Unlock the driver's door then press the 3/4 control. Locking the doors (also arms the perimeter alarm system) Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered. This is a cut and past from this post http://www.fordf150.net/howto/keypad1.php |
