Old 09-30-2004, 07:06 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
battery keeps dying on me!
Everytime i have to jump start it, then by morning its dead! My battery light is also on so I assume there connected. The battery is brand new, the starter and alternator are less the 2 years old. Electrical trouble shooting is not my strong point, any thoughts?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 09-30-2004, 07:28 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: battery keeps dying on me!
If your alt is good then you have a constant drain somewhere. Hook a analog volt meter up to your battery - alt. Then start pulling fuses. When you pull a fuse that bounces the voltage you know your drain is on that circuit.
1969 Cougar
357w & TKO - 475hp
Old 09-30-2004, 08:27 PM
ITFD ITFD is offline
Are you sure the battery is dying? Make sure the battery connections are real clean.
Happened to me where I had to boost it to start it but the alt kept enough power to run the ignition
Old 09-30-2004, 08:46 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Check all the lights, glovebox, under hood (if equipped)
Sometimes a switch goes bad...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 09-30-2004, 11:55 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
First thing is just check for a drain.... If you have none common culprits is #1 bad battery connection #2 dying alternator the stock 5.0's alts are notoriously undersized for the job #3 Bad battery. #2 & #3 about even.
I had an alternator that was under a month old be bad and a battery that was only 4 months old bad at the same time. They worked well enough to start the car run it no probs and shut it off for a while and start again but overmight and it was dead teh next morning. One took out the other so don't rule em out until you test them. Autozone and such do it for free.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 10-01-2004, 12:35 PM
I just realized something last night. I dont know how I did it! My main engine ground is hooked up from the neg. terminal to the metal fender area and not the block. What would that cause? Otherwise I'll check later today for any drains. What setting on my voltmeter should I use and how much of a drop would indicate a drain?
Old 10-01-2004, 12:52 PM
DRW1000 DRW1000 is offline
That would cause an inefficient return path for all electrics. Of course maximum current needs to be available when cranking your engine so you may be on to something here.
Any reason why it is connected here?
Old 10-01-2004, 10:39 PM
wildstringer's Avatar
wildstringer wildstringer is offline
you can use a volt meter or just disconnect one of the battery terminals . hook one end of a test light to the cable and attach the other to the batt term. if it lights up there is a drain . just remember if the door is open the light is going to stay on cause of the dome light . then like 351 said just pull fuses til the light goes out .i made a similar device only with a audible sound its hard to see the light when you are under the dash with the doors closed. LOL
"If the devil danced in empty pockets, He'd have a ball in mine "
87 LX 5.0 - I'm not even going to say what I've done to the car cause when I see how much more I want to do I wanna cry.
Old 10-04-2004, 06:14 PM
Well I tried disconnecting the negative terminal and using a test light between. It did not light up, no drains using that method. I'll still try the pulling fuses method once I find my voltometer. I also transfered that main ground to the block and it did not change a thing. If I disconnect my battery the alternator does keep running the vehicle so I know its not my alternator. So thats leaves me w/ one possibilty....a bad battery. I guess theres a first time for everything cause I've never gotten a bad part before. Its warranteed anyways so at least I can get a new oned and see what happens. Any other thoughts, opinions or comments anyone?
Old 10-04-2004, 06:15 PM
Go Optima!!!
Freedom Isn't Free.
Old 10-06-2004, 07:49 AM
blue_GT_89 blue_GT_89 is offline
you might want to flush your cooling system because if your engine isn't properly grounded, electrolysis can cause a chemical reaction in your coolant and your coolant can quickly eat away at water jackets, radiators, or more than likely your heater core.
Old 10-06-2004, 08:31 PM
Fixed!!!
There were two things causing the mis-charging. The white/black signal wire on the lower alternator connector was broken from the other white/black wire it connected to. My alternator also had an internal drain, which I never would have guessed. Thank god I have people at my work who like to help people out in need! It's now charging right around 14.5 volts running. And most importantly, the battery light is out! Thanks to all for your thoughts and help. I might be getting some quarter times this weekend too. WooHoo!
