Old 09-28-2004, 08:33 AM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
building a 383 stroker
well everyone ive decided to build a 383 stroker this winter but i have a few questions before i start this project, i plan on pushing out huge amounts of power for a while just to break in the engine im hoping to hit the 500 hp at the wheels range on N/A but then im going to either just plain s/c it or put a blower on i can;t decide yet but i know once i do that my power range is going to be massive so i need to find a rear end that can handle that much power and a tranny, for the tranny i can;t decide if i wanna get a built up TH350 or a borg warner t56 so some input would be greatly appriciated. also has anyone delt with http://www.strokerkits.com/build_your_own_383.htm i was thinking of using them for the stroker kit with dart aluminum heads along with their race ready blocks or competition blocks i don;t even care about emitions my car will be 20 years old soon so i won;t have to worry about it considering once this is don;t its only comming out of the garadge once or twice a week
Thanks, Jon
Old 09-28-2004, 10:14 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: building a 383 stroker
ok, first things first, get realistic. not to be a dick, but your not gonna be able to build a 600hp 383 Naturally asperated, and then be able to throw a supercharger or a turbo on it without it grenaiding into lots of little peices. besides once you have 600hp why would you want more for a daily driver???? if its gonna be a race car than i can understand. In any case, the reason for this is that to get that much power out of a 383 naturally asperated you will have to run high compression and a certain cam profile, to run any power adder that works through pressurizing the intake charge, you have to run lower compression, say 8.5 or 9 :1. youll be running at least 10.5 and maybe 11 :1 to get 600hp out of a NA 383. and superchargers and turbos like different cam specks, i reccomend emailing compcams a qustion and have them elaborate. you have to pick which direction the engine is going to take and then follow that idea.
for the transmission, a th350 is a very good choice, a T56 is also a good tranny, but i would definatly spend the money to get the Viper level tranny and avoid any and all boneyard trannies like the plauge.
rear end, methinks your only option is a moser 12 bolt mod or a ford 9in rear, the factory 10 bolts just wont survive under that kinda power. if you have a 9 bolt rear i have heard of them surviving behind 500hp big blocks but your looking to go quite a bit past that number.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 09-28-2004, 02:24 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
the baseline moser (30-spline axles, posi, standard forged yoke, richmond gears) will handle up to 600 lb-ft of torque at the flywheel (with 3.73 gears, goes up with 3.42). couple hundred bucks more to go up to 31-splines and you can go up to 700 lb-ft...
*Better power-to-weight ratio than a C6 corvette*
Old 09-28-2004, 03:25 PM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
th350 tranny is good, but i cant see that to handle that much horse power, i would go with a th400, cant they handle more
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
Old 09-28-2004, 05:04 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Liek 89IROC said you can't build a stroker SB to make 600HP N/A and then throw any power adder on it after to make more. The block would have to be torn apart and all new internals for high psi set-up would be needed. Basically you need to chose N/A or power adder route before you start building this motor when your goal is 600+hp out of a SB.
Also S/C or turbo is your best way to go to get 600hp out of a SB and keep the best street manners.
Rear-end built 12-bolt or Ford 9, from Moser, Strange, etc.., will do.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 09-28-2004, 05:26 PM
Dober89 Dober89 is offline
If you plan on driving the car alot forget about the 3 spd automatic. Definately go with the T56 or atleast a 4 speed automatic.
For rearend I would go with a ford 8.8. Theres a guy up here in ontario that makes them to bolt right into 3rdgens and they are much quieter than a 12 bolt or 9 inch, as strong as a 12 bolt, and have less parasitic losses than both also.
Old 09-28-2004, 07:32 PM
ok well what am i looking at n/a around 450? because i wanna break the shit in before i supercharge it either that or just build the motor and then save up for money and slap on the supercharger and then drop it in the car. also its not going to be a daily driver anymore more like a weekend car considering im gonna have my POS winter car to rock in the rain and hopefully a bike when its sunny out
Old 09-28-2004, 11:00 PM
89IROC&RS's Avatar
basicly what i would say is your 383 is gonna be a torque monster naturally asperated. aim for a 9:1 compression, 400hp, and probly 500lbs/ft of torque. then supercharge it and youll easily get 600hp and with the right tuning you could get more.
Old 09-28-2004, 11:28 PM
well i know a blower puts down more power than a reg supercharger right and i think im prolly gonna go with the t56 b/c i miss driving stick prolly gonna add in a 10 point roll cage since i know ima need it at the tracks
Old 09-29-2004, 12:50 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
look into the forged kits summit has.... they can handle the the s/c's nitrous and turbos... the rotating assembly alone costs around 2000...im dropping mine in turbo and all....along with a t56
Old 09-29-2004, 04:19 AM
mike123 mike123 is offline
b4 you really start to plan all this out you better make a budget cause your gunna get out of hand and not beable to aford it you gota figure on machine work , your technical skills ,and the purpose
Old 09-29-2004, 08:07 AM
funds should be ok i haul in about 350 a week and me and a buddy are starting a catering business too
Old 09-30-2004, 01:39 AM
figure around atleast 500 bucks for all the machining... thats how much its costing me... and this dude does good shit
Old 09-30-2004, 01:56 AM
twdz28 twdz28 is offline
what ever you think its going to cost double it!!! i have built three 383 LT1's, one 383 LS1 and all of them came out double what we thought they would cost... but have fun with it becuase the power after its all said and done is great!!!
95 Z28 Black on Black on Black. Mods: 355CI and lots more...
Originally Posted by Mordant
I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible.
Old 09-30-2004, 05:57 PM
well which one is better 383 LT1 or a 383 LS1
