Old 09-23-2004, 11:38 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Coolant??
I just had the LOW COOLANT light pop up on me the other day. I just broke 70,000 on my truck last week and I think it still has the origonal coolant in their. So im guessin its time to change....But my question is, Should i use the pink stuff that comes in their and is in the manual? I heard a few people say that its not too good to use the pink shit, But then why would they put it their from the factory? Anyway... if anyone has any suggestions one weither i should use what the manual calls for or should i go to a better brand. Let me know what to do guys.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 09-23-2004, 12:03 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Coolant??
If your adding to the coolant thats in it now, you Dex-Cool, if you want to flush the system, you can re-fill with either green or dexcool, just do not mix the differnt kinds. I've heard that the green is better for the cooling system in the long run.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 09-23-2004, 08:11 PM
silveradoman silveradoman is offline
Re: Coolant??
it is, I just had to have my intake manifold gaskets replaced, after 40K
Old 09-23-2004, 09:55 PM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
Re: Coolant??
Wow, another bit of great info. Add changing the coolant from pink to green to the list....
I always thought you couldnt change if you had the new stuff.
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
Old 09-23-2004, 10:48 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Coolant??
Get rid of the Death-cool. Flush that shit out and get the good ole green shit in there...
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-23-2004, 11:18 PM
killerkatana75's Avatar
killerkatana75 killerkatana75 is offline
you can go from pink to green, but not from green to pink....and just like a month ago they now have yellow which will work in either system
Old 09-24-2004, 07:28 AM
Nigel215's Avatar
Re: Coolant??
kool....looks like im gettin some of the ole' green shit. now, how do i go about flushing the system?
Old 09-24-2004, 07:38 AM
jeverett's Avatar
Re: Coolant??
This is how I used to do it at the service station I worked at. Drain the coolant thats in it now, leave the drain open, remove the coolant resivor cap and start the engine. Let it get up to operationg temps, and use a water hose to steadily keep water going into the system. After about 10-15 minutes of doing this, it should be clean. If this didnt make any sense, just tell me and I'll try to explain it again lol
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 09-24-2004, 08:09 AM
Nigel215's Avatar
Re: Coolant??
No, that makes sense, ill give it a shot when i get to changin the coolant. Thanks.
Old 09-26-2004, 05:27 PM
skipr skipr is offline
What about the orange crap? I was told the green glycol does not have the anti corrisive properties that are needed for the aluminum and that plastic crud (mylar I think) that the upper manifold is made of. But then again I have been told alot of things that turned out to be bullsh%#.
Old 09-26-2004, 07:59 PM
broughy84's Avatar
Re: Coolant??
don't listen to that shit, the facts are that the dexcool is more damaging to the system because it eats away at gaskets. I have a 88 chevy silverado and it has over 150K on it, it has all original cooling system minus the water pump. It has always ran the green stuff.....BTW It has an aluminum intake, aluminum radiator, and aluminum heater core....Death cool is bad stuff.
Matthew Brough
Old 09-26-2004, 08:04 PM
nineball481's Avatar
nineball481 nineball481 is offline
Nigel-
Check out "low oil pressure" post by estone4009. In there a few people started to have a coolant leak into the engine at about 70,000 miles...This maybe something you want to look into. The end result for those guys was a blown engine.......
I know that isn't something you want to here, but better safe than sorry....
Here is that post:
http://www.automotiveforums.com/vbul...d.php?t=290114
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 09-27-2004, 08:53 AM
jeverett's Avatar
Re: Coolant??
Yeah, be careful dude. The only reason I haven't swapped mine out yet is b/c of the warranty on my new engine. I don't like paying $10 a gallon for some orange junk anyhow. Why pay $10 when you can get it for like $4?
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-06-2004, 06:34 AM
RPSTELMA RPSTELMA is offline
Re: Coolant??
I have a 1999 Z71 with 83K on it. I found that the factory hose clamps which are the squeeze kind will leak and I got a low coolant light coming on. I took and replaced all my factory hose clamps with the regular screw ones. Also the coolant, the pink or red stuff is a 100,000 mile coolant. If you replace it with what ever coler you use mix it 50/50 with distilled water, it dose not have any metals or minerals in it. I will not clog your radiator and will lubricate your water pump. I had a car with 170,000 miles on it and did this. I never replaced a water pump or thermostat or hoses. Oh one other thing the color of the antifreeze dose not mater one bit, the manufacture puts it in there, just don’t mix the colors.
