Old 09-21-2004, 06:34 PM
estone4009 estone4009 is offline
Exclamation Low Oil Pressure
I have a 1999 5.3L silverado. The idiot light keeps coming on saying I have low oil pressure when you go to a stop in the truck. The gauge on the dash reads about 2psi. I know the mimimum is 5psi. This truck had both head gaskets replaced several months ago for a coolant leak internally and at the same time the oil pressure sending unit was replaced. Does anyone know the easiest way to put a mechanical gauge on the truck without having to remove the intake manifold? The oil sending unit is on the drivers side up next to the firewall. Here are possible causes I've been given:
dying oil pump
clogged oil pickup screen
loose oil pickup screen
This truck has 85000 miles on it. Would I be better off to do a junkyard engine swap or just trade the headache in?
Thanks,
Eric
Old 09-21-2004, 09:59 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Low Oil Pressure
OR your bearings are shot from the antifreeze oil mixing. Is the truck knocking or anything. 2 psi IS LOW. DANGEROUSLY LOW. I would put some 20W50 in that baby and trade-er in, let the dealer figure it out.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-22-2004, 05:57 AM
gtmud gtmud is offline
Depends how involved you want to get. If the truck has been good to you, and the body and drivetrain arestill in good shape, I would take the extra time and do one of 2 things, First put the mechanical guauge on it, if still reads low, good chance that your bearings and or pump are gone. Pull the engine, send the crank into a shop to be turned and replace your rod and main bearings along with the oil pump and pick-up tube. It sounds like a lot, but from experience this works, and you'll get MANY more miles out of your truck. Inspect your bearings, and crank BEFORE you pull the engine. You might be able to get away with just replacing the beaings and oil pump, and not have to pull the engine. Good luck.
Old 09-22-2004, 03:55 PM
Is it possbile to put a mechanical oil sensor on without removing the intake manifiold? And is it possible to change the oil pump and pickup screen without pulling the engine? I was under the impression that you could not get to the oil pump any other way.
Old 09-23-2004, 06:26 AM
It depends how things are set up under neath the truck. If it looks like you can remove the pan , then you might have to raise the engine to get the pan to clear the engine, ie. unbolt the mounts and jack the engine up enough to clear the pan.
Do you hear anything when the engine is running, rod knock? I would do everything possible to put the mechanical guage on to double check your oil pressure, BEFORE you tear into the lower-end. If you have to redo the lower -end, do EVERYTHING. Don't skimp, you want to do this once, not twice. Replace your bearings and if it needs it, turn the crank. then you won't be worrying about if it will work or not. I have a 91' 4.3 w/160K+ on the original oil pump, more than likely your bearings were washed out, so just changing your pump probably won't fix the problem.
Old 09-23-2004, 08:49 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Mine just did this, EXACT same problem. I had the head gaskets replaced b/c of an internal coolant leak, and 20K miles later, the engine locked up completely, but I still had abotu 30 psi of oil pressure.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 09-23-2004, 12:11 PM
Did you fix the engine or just put a new one in? Did you ever determine exactly what caused it?
Old 09-23-2004, 05:06 PM
nineball481's Avatar
nineball481 nineball481 is offline
Re: Re: Low Oil Pressure
jeverett- I just bought my truck last March. Ive been looking through here to see at what mileages things are going out.... Do you know what mileage you had on the truck when you had the internal leak fixed?
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 09-23-2004, 05:08 PM
I currently have 52,000 on my '00. I understand that a lot of u-joints go out around this time....
  • Hypertech PP III
-Nineball
Old 09-23-2004, 08:39 PM
My leak started at about 75,000 miles.
Old 09-23-2004, 09:10 PM
jeverett's Avatar
It was about..72K to be exact. It had leaked 3 coolant bottles into the oil, and I never could find it, until I changed the oil. I had new head gaskets put on, and all was well until 96K, when I spun a rod bearing racing someone, and a week later the engine locked in the middle of an intersection. I had the whole engine replaced with one from a salvage yard that had been rear-ended and totalled w/ 55K on it Got that engine in w labor and everything was $2500..waaay better than the 7000 the dealer wanted.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 09-30-2004, 08:19 PM
I put a mechanical gauge on it and it idles at 5psi and NEVER goes about 25psi at full throtle. I know it is a matter of time before this engine goes. If it was your truck would you get the engine rebuilt or just trade it in to a unknowing dealer?
Old 09-30-2004, 09:01 PM
broughy84's Avatar
5 is a little to low. I would get a thicker oil in it, it will make it last a little longer.
Matthew Brough
Old 10-03-2004, 01:06 PM
5 PSI!! Don't drive it!! Open it up, and spend a weekend replacing the bearing s and oil pump/pick up tube. You can do this in your driveway IF your careful! Or pull the engine, remove and turn the crank then all the other stuff(bearings, oil pump).
Old 10-03-2004, 05:38 PM
Does the engine have to be pulled to do that? Or can it stay patitaly installed?
