Old 09-18-2004, 06:35 PM
bigpig bigpig is offline
tranny question
hello out there, well earlier i posted that i wanted to swap a auto c-4 tranny for a manual t56 out of a 93 cobra.... one thing i forgot to mention is i am actually thinking about 2 of them, one being the t56 and the other is just the world class t-5. i was origionally going with the t-5 but started to worry about the strenth of it and if it could hold up to around 325-350 ft-bl of torque. then i discovered the t56. but i guess my question would be can the t5 handle that much torque if i decide to race it every once in a while. and if not could i beef it up at all cuz ive been to several different tranny shops and they all say there isnt much you can do... but common sence tells me different, this is why i now turn to the experts... help me out guys....thanks
Old 09-18-2004, 07:33 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: tranny question
WC t-5 is rated between 305-325 ft-lb.
I'd go with the Tremec T-56. Once I have enough money thats the one ill be picking up.
Old 09-18-2004, 10:52 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
#1 93 Cobras have T-5Z stock not T-56. Just mentioning if that's what u thought unless some1 switched a T-56 into a 93 Cobra.
#2 If you only race occasionally and your not on slicks a WC T5 should last you a while. Even if your on slicks you got a good chance of being ok.
#3 Your tranny shop guys are wrong there is a lot you can do to T-5's none of it is cheap I admit but when compared to the cost of a used T-56 and all the stuff to install it behind a 5.0 Fox it's is cheaper even if you went crazy on your T-5. Talk to Hanlon(Bob Hanlon's wife will make you laugh I guarantee it!), G-Force, Astro Transmissions
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 09-18-2004, 11:54 PM
andrewespo's Avatar
Re: tranny question
GTStang how is the install on the T-56?
Old 09-19-2004, 09:29 AM
GTStang's Avatar
Stang Guy
The install of a T-56 into a AOD Fox labor wise is not really any more work than switching to a T-5 but parts wise it's more money. Look at D&D Performance they sell conversion kits for a T-56 into a Fox so you can see the extra parts needed. Also you need to have your driveshaft shortened 1/2" inch(something like that).
Old 09-19-2004, 10:28 AM
andrewespo's Avatar
Re: tranny question
The T-56 into a manual 5spd is less work im guessing. Reason I ask is because soon im going to put a T-56 in my 88 which is a T-5.
Old 09-20-2004, 12:15 AM
Future303 Future303 is offline
Re: tranny question
A T-56 is tempting to be able to switch to 3.73 gears and still keep a decent hwy fuel economy.
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 09-22-2004, 11:17 AM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
i have a T-5 and im running about350HP and the tranny i have now is holding up good i even ran some miky ET and had no problems. how ever i have been very kind to this tranny and befor the tranny i had now i had twisted my imput shaft and mest up some gears but i really was hard on it. so the T-5z should hold up no prob. i hear there are safe to run on slicks till low 11s. thats what they told me when i was replacing my first tranny.
Old 09-26-2004, 11:30 PM
burly94gt burly94gt is offline
Re: tranny question
hey gt, do you know if that t56 will bolt straight up to a 94gt auto to man. swap
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 09-27-2004, 12:18 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: Re: tranny question
i speaka da enlish weller =P
you have to have a special bellhousing, and in some applications the clutch is different, in terms of input shaft spline. depends where the tranny came from. call D&D performance (www.ddperformance.com).
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 09-27-2004, 02:51 PM
Re: tranny question
preesh!
Old 09-27-2004, 06:30 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Ever look at the ratio's of a T-56/T-5? The "extra" gear is in between a T-5's 4th and 5th, so your RPM's wouldn't change.
Also, a '93-95 Cobra tranny isn't quite Z-spec, they are a standard T-5 with a bigger input bearing and phosphate coated gears. Still weak.
I'm switching to a TKO500.
All you need to switch it is an 87-93 style clutch fork and a Tremec-specific clutch. Some places recommend a 3/8" spacer for the driveshaft, but I've been told more than once that the slip yoke accomodates that 3/8" very well.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 09-28-2004, 02:03 AM
Re: tranny question
Are you serious man?? So what's the point of it then if 6th gear is really 5th gear on the T5??
Also another question.
Is it possible to get aftermarket gears with different ratios?
For example, the stock 1st gear is 3.35:1 ratio, I would like to switch this to something with a higher ratio, like 4:1. Is this possible??
Also, I'd like to switch 5th Gear to 0.50:1 from the stock 0.68:1.
Is any of this possible? I've been looking for info on the net but have not had any luck with finding info.
Old 09-28-2004, 08:06 AM
OK right from D&D's site
T-56:
1st-2.97
2nd-2.07
3rd-1.43
4th-1.1
5th-.80
6th-.62
T-5 (according to Ford's literature)
1st-3.35
2nd-1.99
3rd-1.33
4th-1.0
5th-.68
TKO 500 (from Brothers Performance website)
1st-3.27
2nd-1.97
3rd-1.34
4th-1.0
5th-1.68--EDIT Typo...Meant .68
D&D also sells a Viper-spec T-56 which has the .50 6th gear, but the expense of that isn't really attractive when it only holds 50 lb ft more than a TKO500, and I'll never bust the TKO.
Personally I don't mind cruising at 2600 RPM. My motor is balanced and built to handle 7000 RPM, so... Besides, I'm right in the bottom of my torque curve there, so I don't even downshift for pesky ricers on the interstate, I just stomp on the gas.
Freedom Isn't Free.
Old 09-29-2004, 01:48 AM
hp_lover hp_lover is offline
Re: tranny question
ok, well then if i go with the t-5 and maybe it doesnt handle the amount of torque im producing, would the t-5z match up exactly like the t-5?, or are the other mods i need to make. thanks
