Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 02-11-2002, 02:25 AM
RSScamaro RSScamaro is offline
Send a message via AIM to RSScamaro
SUPERCHARGING vs. TURBOCHARGING
thoughts a opinions on these 2 paths to choose for better performance as well as pro's and con's of the 2...they are similar but some poeple might like one more than the other
:greenchai
:monkeypis mustang
Rss
Old 02-11-2002, 04:32 AM
F20C's Avatar
F20C F20C is offline
I think it depends on the car and what you are looking for out of the car.
Old 02-11-2002, 10:03 AM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
turbo charging depending on the size of the turbo will produce lag until engine rpms reach boost point, while supercharging will give power from a lower rpm but still produce through out the rev range.
Turbo charging can and will produce peaky hp while supercharging will produce smoother hp curves.
For open road or circuit style racing turbo charging is better while in drag racing super charging is the way to go. Of course that also depends on the size of the engine. Turbo charging is also known as cheap hp
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 02-11-2002, 01:45 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Superchargers are more expensive and vibrate a lot. Generally, turbo charging is better.
Old 02-11-2002, 02:06 PM
turbocharging either of my camaro's would be atleast 2 grand more than supercharging it..ive looked....supercharger with aftercooler installed would be around 7 g's and twin turbo kit installed would be no less than 9.....i dont favor one over the other but i do favor not being broke..haha...peace
Rss
Old 02-11-2002, 02:28 PM
del del is offline
móddə rąytər
supercharging would be more ideal for a daily driver. turbocharging is more flexible than a suercharger, better for racing overall. turbos are generally much higher maintenance. if you don't take care of it properly, you'll run into costly problems. i mean you have to take care of the car, supercharged or turbocharged, but between the two, the supercharger requires less maitenance attention.
Old 02-14-2002, 06:58 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
you are obviously going with centrifugal s/c, which needs to be stated. that can make alot of power, and is more of a driver's car. why not build one of each?
the question is really more along the lines of what other mods are you going to have to make? if you tt, it is more power, which means more "hidden" mods, or, the stuff you have to do b/c you tt'd it. the s/c isnt as bad, but it still has em. it just depends on how you want to spend you money. you can spend more on tt's, only to find out you are going to have to spend more in "hidden" mods... but it could be the same w/ an s/c. i would consider that. what kinda power numbers are we talking, and what kind of powerbands?
Old 02-14-2002, 09:51 PM
im talking over 620 horses when i got done!
Rss
Old 02-15-2002, 01:07 AM
Someguy Someguy is offline
Send a message via AIM to Someguy
I disagree with that one big time... In road racing, torque coming out of the corners is a huge advantage, which a roots type blower provides. Why do you think Mustangs and Camaros romp all over S2000s in T2 (nationally) when the S2000 has about the same hp/weight ratio and has a better suspension and is lighter? A roots type blower does wonders for auto-x and/or tight road courses since low end torque is nearly equally boosted as high end power.
But RS, what motor are we talking about here? If its a 350/LT1 then you are getting ass raped if you think a blower w/ aftercooler will run you $7,000. A LS1 kit, which is generally much more expensive, will only run about $5k installed. If by chance you are running a 305, then why the hell are you running a 305? Get a real motor.
Old 02-15-2002, 12:20 PM
im putting a vortech g-trim sq supercharger w/aftercooler in with a polished finish....go to vortech's web page once and look it up..i think its around 5500 or so....im putting this in my 2000 SS....i was thinking bout twin turbo for the LT1 down the road sometime
Rss
Old 02-15-2002, 12:27 PM
$6,434.30 exactly from vortechsuperchargers.com....that does seem a little expensive...but its a +150 horsepower boost...so i'd do it
Rss
Old 02-15-2002, 05:42 PM
USA Racer USA Racer is offline
Wink
Both.
Nowadays turbos are probably the better choice.
Old 02-15-2002, 10:31 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I would have to go with a TURBO hands down.
Old 02-16-2002, 01:51 PM
Steel's Avatar
Steel Steel is offline
i like superchargers more, personally. Im an old muscle car kind of guy, so just for pure aesthetics, a nice big ass blower sticking out of the hood of a nice car (say, Hemi Cuda, hehe) it just sweet. Also, whenever you hit the gas, you can watch those butterfly valves open. Also, for the musclecars, big V8's, that produce a lot more power on the low and mid rpms, its better to have a s/c to provide for that, instead of a turbo which will lag until it's too late for the larger engines. So. Yeah.
Old 02-16-2002, 10:39 PM
MBTN's Avatar
Smile
Superchargers add friction, are "lazy": they help low-end power, but they don't rev as fast or as high as a turbo car would. They also vibrate a lot.
Overview: Supercharger vs. Turbocharger igor@af Technical Articles 11 09-12-2008 10:01 PM
supercharger Vs. turbocharger 03'350z Mustang Talk 7 06-10-2004 02:12 PM
Overview: supercharger vs. turbocharger texan by texan (Brian) 28 11-23-2003 01:15 PM
Supercharge Vs. Turbocharge! LLKoolE7 Accord/TSX/Accord Hybrid 9 03-28-2002 09:09 PM
Supercharger vs. Turbocharger howard_w13 Engine 3 11-29-2001 05:29 PM
