Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 02-10-2002, 02:14 AM
GtRider GtRider is offline
Send a message via AIM to GtRider
Post Knock sensor
i own a 94' and iam gettin a error code 3,4 which means Knock sensor ?
anyone has any info about this sensor?
94 G20t
Old 02-10-2002, 03:57 PM
Cue-Ball's Avatar
Cue-Ball Cue-Ball is offline
I don't have any info about that particular sensor but have you advanced your timing? Have you checked your timing to make sure it's correct? If you're running advanced timing and are not using premium fuel, your engine will "knock". This could be what's tripping the sensor.
Or, it could just be that your car is getting older and the sensor is going out. <shrug>
1999 Infiniti G20t
17" RH Evolution M7000's with Toyo's
Mostly stock...for now.
Klaatu Varata Niktu
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 03:25 AM
Crazy knock in 3rd, o2 sensor or knock sensor bad? nates6969 Eclipse Problem Diagnosis 16 06-23-2006 09:11 AM
Knock Sensor and ECT Sensor snizzugglesmaxima Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 10-05-2004 06:53 PM
2000 Yukon How to Replace Fuel Sensor & Knock Sensor mrchiqui Yukon 0 06-24-2004 05:55 PM
Knock sensor and O2 sensor jmmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-24-2004 11:51 AM
