Old 02-10-2002, 01:49 AM
jinushaun's Avatar
jinushaun jinushaun is offline
Send a message via AIM to jinushaun
Cleaning brushes
Alright, I finally started my model today. I'm finished with the primer and waiting for it to cure. I also painted of the engine parts. Anyways, how do you guys clean your brushes--or how do ya'll paint with brushes?
When I was painting, the paint slowly dried on the brush. When I finally went to clean it (in water), it wouldn't come off. I'm probably wrong in thinking this, but I even tried thinner.
Help?
Jinushaun: Nation Leprechaun
Old 02-10-2002, 01:58 AM
awaken1973 awaken1973 is offline
Send a message via ICQ to awaken1973
I usually clean brushes in nail enamel remover. It's better to do immediately after use. But if paint completely dried you can left your brushes in solvent for a longer time (e.g. for a hour)
When switching from one paint to another I just dip brush to the jar with remover and then wipe it with cloth
Current project: Tamiya Porsche 959, red
Old 02-10-2002, 02:09 AM
Thing-A-Majig Thing-A-Majig is offline
maybe you should try using acrylic paint? just a suggestion. i like it better because of its easy clean up, and faster drying.
Old 02-10-2002, 03:13 AM
primera man's Avatar
"P-Man"
I use stuff from my work called *CONKER*, It's brilliant. It washes all the paint out of the brush then can be washed out in water.
You use the stuff on car engines to remove oil/grease and then you just hose it off to make you engine look all nice and new
View All My Models Here.
Old 02-10-2002, 08:56 AM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
You did'nt mention what kind of paint you're using (enamel or acrylic)
for acrylic paint,soap and water should clean the paint off the brush.
Enamels need Mineral Spirits,Turpentine,or paint thinner.Brushes
should'nt be left long enough for the paint to dry on the bristles.
Don't leave the brush in a jar of cleaner too long or it will bend the bristles permanently.
Mike
Old age and treachery will overcome youthful exuberance everytime !!
Old 02-10-2002, 04:24 PM
jinushaun's Avatar
Thanks everybody for the help. Sorry that I forgot to mention that I use enamel paint. It's Testor brand. Is Tamiya acrylic?
Old 02-10-2002, 04:25 PM
Jay! Jay! is offline
Horizontally Opposed
Originally posted by jinushaun
Is Tamiya acrylic?
Most Tamiya jars are acrylic. They do make Tamiya enamels, but I've never seen them. Tamiya sprays are synthetic lacquers.
Hierarchy of Subaru:
(Click to see mine!)
Old 02-10-2002, 10:50 PM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
In New Zealand we are spoilt for choice when it comes to Tamyia we get the full range of Acrylics and Enamels and the TS and AS spray cans
The Enamels clean up good in paint thinner, just don't leave the brush in there because it eats the paint off of the brush itself
Old 02-10-2002, 10:57 PM
JE123's Avatar
JE123 JE123 is offline
I have yet to even see a Tamiya acrilyc in person, let alone a Tamiya enamel.
I have to settle with Testors and Model Master enamels and acrilycs. They aren't bad. I use Paint thinner to remove enamel from a brush.
-Joshua
Exterior Cleaning ? - Acura TL ShineForMe General Discussion 2 04-19-2010 04:35 PM
Cleaning O2 Sensors CCMphysician Engineering/ Technical 4 01-15-2010 07:47 AM
brake light and dashboard cleaning sailor86 Engineering/ Technical 4 12-29-2009 07:40 AM
cleaning brushes superhoss Car Modeling 7 10-05-2002 06:04 AM
