Old 09-10-2004, 06:51 PM
gftb5's Avatar
gftb5 gftb5 is offline
which should i get first?
an underdrive pulley or CAI
Old 09-10-2004, 08:16 PM
wildstringer's Avatar
wildstringer wildstringer is offline
i know im going to kick myself when ya tell me but what is CAI
Old 09-10-2004, 09:23 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: which should i get first?
CAI is cold air induction. It replaces the stock air cleaner box with a conical filter.
I would suggest the under drives first. You will see very little to no gains with the CAI and surely will not feel the gains. If you wanted to see the gains you would have to dyno the car before and after. Personally I think CAI is just a rip off.
1969 Cougar
357w & TKO - 475hp
Old 09-10-2004, 09:36 PM
brentmcq brentmcq is offline
I would go with the CAI first. The underdrives are good if you plan on getting lower gears to slow down the accessories up front. UDP's only give another 5hp and CAI can give 10-20 depending on the vehicle. I have both on my 2000 and noticed a bigger jump from the CAI.
2000 GT 4.6L 5spd, BBK cold air, BBK 75mm TB, Bassani catted X-pipe, (no headers) FM catback, 390 gears, SCT chip, Steeda Pulleys, ported stock plenum, Comp Cam XE262AH. RWHP 260, Torque 282
Old 09-10-2004, 09:43 PM
well they both will add about the same hp at least thats what they are advertised i just think the cold air is more for looks though .by the way i knew id kick myself.
Old 09-10-2004, 10:00 PM
351wStang's Avatar
How the hell does lower gears slow accessories?
1969 Cougar
357w & TKO - 475hp
Old 09-10-2004, 10:15 PM
well it ... yeah theres the...wait a minute yeah what 351Stang said
Old 09-11-2004, 01:28 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
I think what he's getting at is that if you put lower gears in the rear with stock pulleys, your accessories turn faster due to increased engine RPM at a given speed, with underdrives they'll slow back down.
My .02 cents: CAI gives you the same gain as a K&N replacement filter, just looks better. UDP's are nice but can cause some quirks. Look to your exhaust for gains.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 09-11-2004, 05:44 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I'd go UDP over CAI neither one gives you real large gains but I think the UDP actually give you someting where I feel CAI is mostly looks. Plus UDP for 5.0 and 4.6 don't cause any issues that happened in there earlier days so no drawbacks to them.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 09-11-2004, 07:41 AM
Oops, yeah, I always forget that my UDP's are ancient March ones....They do cause me some charging issues...
Freedom Isn't Free.
Old 09-11-2004, 12:25 PM
It's a toss up. BTW my earlier post was in favor of UDP's "if" lower gears are put in the rear. The higher rpm's increase wear on the accesories, the UDP's will help them last longer. CAI is easy to install, UDP's require pulling the balancer off which is no big deal it just takes longer. Most stock air boxes are very restricted. More air in and more air out = increased HP. Pesonally I'd go in this order: cat back, x-pipe, cai, throttle body, gears, UDP's.
Old 09-11-2004, 12:30 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
well being the mustangs intake is pretty good i'll say pullies would be better
Old 09-11-2004, 03:18 PM
Red 99 Mustang's Avatar
Red 99 Mustang Red 99 Mustang is offline
Send a message via AIM to Red 99 Mustang
how much are udp's? and what do they do?
Old 09-11-2004, 04:48 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
cold air induction
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 09-11-2004, 05:16 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Underdrive Pulleys range between $80 and a $130. Depending on application and metal chosen (steel, aluminum). Underdrive pulley kits basically free up excess power from crankshaft, water pump, and alternator pulleys giving you a little horsepower.
