Old 02-09-2002, 04:20 PM
rcamacho rcamacho is offline
Send a message via AIM to rcamacho Send a message via Yahoo to rcamacho
Question Camber/Caster adj for '94 Civic
I just installed AGX shocks and Eibach Pro springs (very nice ride). The alignment is coming out at -1.8 front camber, +0.2 front caster, -1.1 rear camber.
Q: I deally I'd like to correct for more positive caster and bring in camber to -1.0 or less. Any recommendations on street worthy kits that will not bust the bank?
Old 02-09-2002, 06:06 PM
Rice-Rocketeer Rice-Rocketeer is offline
Re: Camber/Caster adj for '94 Civic
Yeah for the rear use the bolt and washer trick and for the fronts you can use Ingalls kit on www.groupbuycenter.com
Old 02-10-2002, 03:59 PM
Question
It appears that the ingalls kit corrects for camber only. Is there a way to correct for caster?
http://www.ingallseng.com/parts/3572.html
Old 02-10-2002, 04:52 PM
That's why they're called camber kits. There are no popular kits out that correct for caster because frankly:
1. Only 0.01% of the ppl actually know what it is.
2. Why would you want to adjust caster for the street?
Lookin at my gucci, it's about that time...
Old 02-11-2002, 11:06 AM
Cool
With other vehicles I've had I can definitely feel the difference between 0 caster and +3-5 at freeway speed (75+). It's a matter of personal preference, but I like the added stability.
With the current alignment specs, the Civic will follow road irregularities, but will steer out of them with some driver input.
Old 02-11-2002, 03:26 PM
I think that has more to do with the civic's weight and and short wheel base compared to other cars you may have driven. But if it's that important to you, ask the place you got the alignment from to see if they can adjust it for you even if it's minimal.
Old 02-12-2002, 02:52 AM
Si2000 Vtec Si2000 Vtec is offline
Send a message via AIM to Si2000 Vtec
I saw a kit at a local speedshop a few days ago when I picked up my Skunk2 camber kit. It had camber and caster adjustments. They were new control arm replacements like my Skunk2, but were quite a bit more expensive, comin in at a pretty $300 for both arms.
I used the bolt/washer trick on my rear. I used 3 washers, put my camber back to -0.4. My car drives and handles so much better with the wheels actually evently dispercing the weight over the contact patch... its a nice feeling =)
Old 02-12-2002, 03:28 PM
Just ordered the front and rear ingalls kits through groupbuy. Ingalls indicated that the '96-up eccentric ball joint will work on the earlier models so camber and caster can be corrected. Expensive option though, I'll just stick with camber correction for now.
Camber, Caster Alignment? blueturtle00 Windstar 2 03-29-2005 05:39 PM
