Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 02-09-2002, 11:58 AM
GILLY GILLY is offline
Question need help audio system failed
have 93 J30...whole audio system does not work
any suggestions...think it might be a relay or a fuse??
Old 02-09-2002, 07:28 PM
jpalm jpalm is offline
The Bose system is notorious for going bad. You could try the fuse, disconnecting the battery overnight, etc. Mine in my 94 J30t stopped a year or so ago and had a place pull it out. It was a bad soder. If you are experienced then go ahead and pull out out an check it out. If not leave it to the experts...unfortunately not much choice!
Jeff
Old 09-04-2002, 01:01 AM
NoMotive's Avatar
NoMotive NoMotive is offline
Send a message via AIM to NoMotive
My Bose audio system crapped out a while back too... needless to say the Dealership fixed it for about 200 bucks. Went without music for a couple weeks. The speakers have custom amps or something like that, so buying a new head unit required replacing all speakers!!!
Old 09-04-2002, 01:37 AM
boingo82's Avatar
boingo82 boingo82 is offline
Can't polish a turd.
I believe it's just that Bose isn't compatible with anybody else.
You might want to watch eBay also, if you can determine which component is bad. Many times I have seen whole or part of J30 audio systems for sale.
Just because offense is offered, does not mean you have to take it.
Old 02-22-2003, 10:26 PM
mwilken mwilken is offline
I had this problem with my old J-30 and it cost me about $125 to get fixed. Luckily I have a local stereo guy that is real cool and found a guy in California that could rebuild the unit for a flat fee of $75+S&H. I wish I still had those records, I would have been able to give you his information.
Old 10-27-2003, 11:24 AM
tiggermarty tiggermarty is offline
These guys fixed mine for just under $200 (not including s/h) http://www.carstereohelp.com/ - they also give you 1 yr warranty - excellent place to deal with
Old 12-17-2003, 06:17 PM
mavliu mavliu is offline
Re: need help audio system failed
Where is the Switching Relay and fue? for the 93 J30?
I have CD player seem to be working, attenna fine, everything ok but all of a sudden this morning. all the speakers has no sound.
Old 03-14-2004, 03:06 PM
vinbansal vinbansal is offline
Question Re: Re: need help audio system failed
I have the similar problem with my 93 J30 Bose system as well. In extreme summer heat the audio system works intermittently. All components work normally but there is no sound. Any clue as to what may be the root cause. My dealer wants $250 to diagnose the problem. Also, some of you have suggested a relay that turns the individually amplified speakers. How does one find this relay?Thank you in advance.
Old 03-15-2004, 10:18 AM
Less Less is offline
Re: Re: Re: need help audio system failed
I had the exact same problem a few months ago. Took it to a local repair shop. It was lose components, cost $90. I had too many problems with my J30, so I finally traded it in for a Camry.
Old 04-11-2007, 02:43 AM
Donny Campbell Donny Campbell is offline
This may help some of you I had the same problem with Bose system. Bose only manufactures the speakers Clarion makes the unit itself. I bought a Bose 6 disc changer that was in a 2004 350zx for 150.00 bucks off Ebay-just a few inexpensive adapter switches and you would have thought you driving in a brand new Infinity again. It required a little work but was well worth it fits back like the old one did-Good Luck
Need help - Audio system rboit Silverado 4 01-06-2007 07:59 AM
New And NEED HELP... ALL LIGHTS FAIL !!! Southside12345 Expedition 5 06-20-2006 04:15 PM
NEED HELP!!!! Audio Problems xrsxj ES300/ES330/Windom 2 06-17-2004 01:55 AM
Need help with system joe_fh Car Audio 4 07-30-2003 11:31 PM
