Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 06-14-2006, 04:00 PM
Southside12345 Southside12345 is offline
New And NEED HELP... ALL LIGHTS FAIL !!!
I have a 2000 Expo, that since I bought it used, has been great, but for the lights, from turning signals to brake lights, they are all now done, the headlights and fog lights are fine, so are the interior lights.. Just the Signal and Brake.. Any ideas, and yes, I have changed the front one's and NOTHING... I am about to go to any mechanic, but I want to at least have an idea of what going, on or maybe if I can fix it myself.. ANY HELP WILL BE GREATLY APPRECIATED...
Old 06-14-2006, 05:30 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: New And NEED HELP... ALL LIGHTS FAIL !!!
Possibly the multifunction/turn signal switch. Both of those circuits run through the switch.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-15-2006, 01:50 PM
If it is the switch, then how do I go about changing it.. It is toooo difficult ? I just changed all the light bulbs so that there would be nooooo questions about it.. Thank you once again, I am now starting to get somewhere with this problem.. THANK YOU !
Old 06-15-2006, 01:57 PM
way2old's Avatar
TOKEN HILLBILLY
The switch is easily changed. There are about 3 screws that run up through the bottom of the steering wheel trim. Remove these and pry the top of trim up far enough to see the top screw on the switch. It is a T20 torx headed screw. There is also one on the bottom. You may have to remove the tilt lever if it is in the way. Remove both screws, unplug wiring connectors and remove switch. Install new switch into the wiring connectors and see if the lights work. If they do, finish installation.
Old 06-15-2006, 04:26 PM
mtmaurer8ooo mtmaurer8ooo is offline
Just a thought....but have you checked all the fuses yet??? Usually a good place to start. Looks like fuse #13 and #23 (look in the owners manual) have a lot to do with brake lights, signals, and hazards! Might not be, but it might be an easy fix. Let us know what you find. Hope this helps. MM. By the way...if you do want to replace the multi-function switch...check with your dealer first....there was a recall on some Expeditions for the same part. Just FYI.
"Listen to me Hillary. I'm not the first guy who fell in love with a woman that he met at a restaurant who turned out to be the daughter of a kidnapped scientist only to lose her to her childhood lover who she last saw on a deserted island who then turned out fifteen years later to be the leader of the French underground."
Old 06-20-2006, 04:15 PM
Yeah, I checked the fuses and it's not them... I am still a little confused on how to change the switch by there stearing wheel.. ?
