Old 09-07-2004, 12:22 PM
jberry3 jberry3 is offline
How much paint?
Now I finally got round to ordering some decent putty my R34 skyline gtr with sas nismo kit is under way. I want to spray it Tamiya pure white ts-26 which is a 100ml can. On my previous models i used auto spray paint which was 300ml and used about 2/3 - a full can of a can. Would i get away with 2 100ml tamiya cans. Also would it be better to use tamiya clear with tamiya paint.
Old 09-07-2004, 12:54 PM
Spitfire7's Avatar
Spitfire7 Spitfire7 is offline
Re: How much paint?
Yes it would be a good idea to use tamiya clear with tamiya paint. And i find that i only have to use 1 can of tamiya spray paint for each model. Its your call though.
Old 09-07-2004, 01:01 PM
freakray freakray is offline
AF Modelrater
Re: How much paint?
200ml is a lot of paint to lay down on a model.
On a good paint job, I can get a model sprayed with 2/3 of a Tamiya can.
AF User Guidelines
Old 09-07-2004, 01:44 PM
Vric's Avatar
Vric Vric is offline
Re: How much paint?
with a Tamiya spray paint, you are ok for about 8 mish coat. Which could be 2 model or near 3
Old 09-07-2004, 02:39 PM
racer917's Avatar
racer917 racer917 is offline
Tamiya's claim that you can paint 2 cars with their sprays is just too generous. You'd be surprised how much paint a model can take without loosing detail. If you do even light sanding between coats you could get one car body per can. I'm currently spraying the Yamaha Red Bull bike and I've started on the second can of mica blue. In the end I'll use between 1 1/2 to 2 cans of it followed by clear.,
Old 09-07-2004, 03:11 PM
Vric's Avatar
Re: How much paint?
2 can on a bike ? geezz that too much
take a look at my model, no more than 4 coat of paint on them and usually I can make 2 kit with a can with color that cover nicely (non transparant color ie: red yellow white)
Old 09-07-2004, 05:44 PM
RallyRaider's Avatar
Zomby Woof
Re: How much paint?
I find that I use well over a can on a single 1/24th scale model. It depends if you are just diong the bodyshell or if the chassis, wings, rollcage, mirrors, intakes and other things need to be painted the same colour too. A lot of that is waste using it straight from the can. Decanting and using a airbrush makes much more efficient use of the paint.
Old 09-08-2004, 12:05 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: How much paint?
> jberry3
If you use gray and white primer, you'll only need 4 coats of white like Vric suggested.
When working with a body kit, you have to unify the smoothness and color between the resin parts and plastic parts before applying the body color. Apply two coats of gray after body prep is done. And white paint isn't quite opaque enough to hide the gray surface, so apply 2 coats of white primer.
After the body is evenly white, apply gloss white to add sheen to it. Clear coat is recommended, but not a must.
Hiroaki Fukuda
