valve question
what type of measurement tool do you use to check valve lift? Also hoe do you check the lift?
Dial Indicator
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Re: valve question
Use a dial indicator to check lift. Duration and lobe sep. are much different. I'm not sure how you would check them without some fancy tools.
1969 Cougar 357w & TKO - 475hp |
you would need to use a dial indicator . zero the gauge on the butt of the cam lobe rotate engine until the dial indicator is on the highest part of the lobe that number is your cam lift . thats the short version but should be enough to go on . you can do it right at the rocker arm but just be sure you have the indicator set up so you will get an accurate measurement
can i get a dial indicator out of any hot rod magazine pretty much right?
sure summit , jegs , maybe even some local parts stores will have one . you can also get one with the mounting device and contact rods
