Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-08-2002, 10:12 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Angry BAD News: Check engine light on
My friends and I was racing on the expressway doing about 140 we went through some rough spots. When my car rides rough a plug under the distributor comes out and the car shuts off and won't start. This happened before and all i did was plug it back in. On this particular day, we did this and I crunk the car up and the check engine light came on and won't go off. My friends checked the code but I want to make sure they aren't lying to me. The check engine light blinked 7 times. Can any one tell me what this code is and how much will it cost to repair. Thanks!!!! The reason is they are going to be responsible for paying, Long story but get back with me someone!!!
Old 02-09-2002, 02:06 AM
LoudLude LoudLude is offline
a code 7 is throttle angle.
I cant think what would trigger this though?
try resetting your ecu.
Old 02-09-2002, 06:30 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
As above
Try the throttle position sensor on the side of the throttle body. Some are adjustable and others are fixed. Also a vacuum leak can make the light come on. Try unplugging the earth terminal first.:flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
