Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 02-08-2002, 09:39 PM
T4 Primera T4 Primera is offline
Attention those with lowered suspension
I've been wondering, those of you who have lowered your G,
1) How far out was your camber? negative or positive?
2) How much was the drop?
3) What was the effect on tire wear?
I've been told that when the suspension is lowered in a Primera/G20 that the camber goes positive first and them negative again as it gets progressively lower.
If this is true, then there might be a useable range of lowering where the camber will return within spec. This info will be helpful for those people considering lowered suspension to determine whether they will have camber issues vs amount of drop.
Cheers,
Sandy
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 02-09-2002, 03:57 AM
pche059 pche059 is offline
Send a message via ICQ to pche059
Hey Sandy,
When i had my Eibach Springs 30mm dropped, the front cambers were +0.1 and +0.3 left and right respectively.
The outside of the tires were wearing out at a rather unpleasent rate.
It's a P11 i am talking about here
Patrick
99 Primera P11
One stripped down Primera
Old 02-09-2002, 04:40 AM
Thanks Patrick, that's the sort info I'm looking for. If we get enough replies like yours it'll become the definitive camber vs drop reference.
Anyone else??
-- Bertrand Russell
Old 02-09-2002, 09:41 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
On my 1.9" drop my camber was 0 and -0.1.
Old 02-09-2002, 02:15 PM
Thanks, that's within spec. I assume tire wear is even then? Looks like this is within the range of drop for keeping camber in spec without a camber kit.
Haynes lists the camber spec for both P10 and P11 as:
0.75 deg negative to 0.75 degrees positive.
So far, these two replies appear to confirm the original assumption.
Please keep posting your numbers people. I'm hoping to get enough info to construct a graph of drop versus camber for everyone to use as a reference.
-- Bertrand Russell
Old 02-09-2002, 03:10 PM
SE-R_Dan SE-R_Dan is offline
Send a message via AIM to SE-R_Dan Send a message via Yahoo to SE-R_Dan
How are you guys measuring drop? I bought my car lowered with coilovers so I'd be interested to know stock ride height and where it's measured for a 99 G20T. I assume I'd also need to know the radius of a stock wheel/tire since mine are 17's.
Old 02-09-2002, 03:30 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
On my P10 when i lowered my car the camber went negative. At both a mild drop and a pretty extreme drop (intrax springs) it was negative both times. I forget exactly where my front camber is, since it's not adjustable i really don't pay attention to it that much, the rear i did have as close to -1.0 degree as possible. I think the front was even a little more negative (maybe -1.5 degrees?). I havn't noticed any weird tire wear yet, my nitto 555zr tires have lasted over 2 years now, including a track event and a couple times at the drag strip, and still have some tread left. I'd say at least 25000 miles, probalby more like 30000+, and still going. well, sorta.. i have those azenis now, they kick ass
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 02-09-2002, 03:40 PM
I guess they are just measuring the difference before and after or else going by the advertised drop for their springs.
A USDM FSM may have the specs in it - didn't Luke throw one in with the car ???!!! (sometimes measured from the ground to the top of the wheel arch on each corner).
-- Bertrand Russell
Old 02-10-2002, 01:51 AM
Justin, thanks for the reply. Do you have numbers. i.e.
Mild drop = approximately how much?
Extreme drop = approximately how much?
Alignment figures = ??
This just helps to quantify things a little more. It might reveal a difference btween P10 and P11 suspension geometry as well.
Thanks for reminding me, if anyone has a lowered P10 then please include the rear camber change if possible. (It shouldn't change on a P11 log axle.)
-- Bertrand Russell
Old 02-11-2002, 02:41 PM
gdalton's Avatar
gdalton gdalton is offline
Hey if anyone with H&R springs could answer these questions that would be great, I'm thinking about getting them but I don't want to have postive camber to screw up my track times.
05 Big Blue Stepside
“Somebody kicked my dog Mavis and I’m going to find out just who the hell it was. I’m all messed up on cough syrup right now so just like nevermind.”
Old 02-11-2002, 10:59 PM
kenchan's Avatar
kenchan kenchan is offline
2inch drop camber is 0deg as far as I can tell with a a t-square. tires wearing normally as far as I can see.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 02-11-2002, 11:10 PM
JustinP10's Avatar
Guesstimates of course... mild-moderate (where i'm at now) 2-3 finger's worth all the way around, on 195-60-14 tires.
Extreme was with intrax springs, and that was 0 fingers in the front, or even, rear was about 2-3 fingers. I still can't find my alignment sheets Recently I've just used a friend's toe plate to make sure toe is close, as that's all i'm really concerned with, for now, as caster and camber (in the front) are not adjustable.
Justin McClanahan
95 G20
Old 02-12-2002, 12:16 AM
Thanks Justin, ... ummm ... that's a little hard to compare with the other data. How many 'fingers' was your car standard? ... and ... please don't think I'm taking the piss here but .... could you measure your fingers for me? Then I can make a comparison with the other data ....
Kenchan, thanks for the info
-- Bertrand Russell
Old 02-12-2002, 12:39 AM
JustinP10's Avatar
HAHA, yeah, sorry.. I've got skinny fingers too... 2 fingers is about 3.5cm (or a hair under 1.5") and 3 is about 5-5.5cm (right about 2"). sorry, didn't think about that. And stock, i'n not totally sure, but i'd guess about 5 fingers? 8-10cm (3-4") that's between the top of the wheel and the fender. When I measured the ground to wheel well spacing, stock is 658.5mm front and 650.5mm rear. Mine now is 605mm front and 598 rear (average between left and right sides). so about a 53.5mm drop in front and 52.5mm drop in the rear. If that helps more than my not so accurate fingers :hehe:
Justin McClanahan
95 G20
Old 02-12-2002, 01:04 AM
Thanks Justin. Hope that alignment sheet turns up.
Hmmnnn .... only 1 P10 so far
-- Bertrand Russell
How to lower 98 civic cp with factory suspension? Probegt/civic Exterior | bodykits | Lighting 13 10-12-2004 03:58 PM
lowering a 87 stock 87 crx with stock suspension 87 crx pics '71-'87 Civic | CRX 10 04-27-2004 07:56 AM
lowering a 87 stock 87 crx with stock suspension 87 crx pics Wheels/Tires/Suspension 2 02-03-2004 12:50 PM
