Old 02-08-2002, 08:44 PM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
K&N or Spoon drop in filter?
Iīd just like to know out of interest which one would be better? The Spoon drop-in filter or the K&N drop-in filter? Which one has got a better cleaning effect?
This is what Spoon is writing about their own filter : "...Accordingly, the air-intake system of Honda vehicles is considerably complicated, and in accordance with the fact that this enables an excellent pulsing behavior to be realized, random replacement of the air box and/or the intake piping is not recommended. In the case of NA engines with 100 hp or more per 1000 cc, these components have a very important role to play. Accordingly, the Spoon air cleaner was tested with the focus on reducing air resistance to the lowest-possible level, while at the same time utilizing the pulsing operation in the same way at on the normal configuration...". So does the K&N drop-in has got the same `pulsing operation ī like mentioned in the last sentence like the Spoon and the stock drop-in filter have got?
Iīm just curious...
Old 02-08-2002, 09:39 PM
changedagame108 changedagame108 is offline
If you're looking for some real power gains, I'd go with an intake. The drop in filters will add 1-3 hp at most. If you're on a budget, the intake shouldn't be too hard to save up for. Most run for 150-200, depending on if you want short ram or the full cold air setup.
I always recommend the AEM cai; a trusted company that delivers.
Old 02-09-2002, 11:18 AM
Veetec's Avatar
Iīm not looking for some real power gains! I was just wondering which would be the BEST drop-in filter for a 5th gen Prelude. I know that AEM is one of the best but 1.) I like to listen to the pure VTEC sound ( ), 2.) CAIīs arenīt street-legal over here and 3.) I donīt want my new ride to be as noisy as my old one again!
So which drop-in filter is the best one? In the moment Iīm just curious and I havenīt made a final decision yet.
Old 02-09-2002, 12:33 PM
The K&N would be your best bet in this situation. In terms of just an air filter, you'd be paying more for the Spoon filter because of its name.
Old 02-09-2002, 12:55 PM
texan's Avatar
texan texan is offline
Writer Mod
If you want to open up the sound some, just remove the resonator. I assume this is an H22 equiped Prelude, the resonator should be in the same location there as it is in the US, so here's a page showing removal instructions.
'03 Corvette Z06
'99 Prelude SH
Old 02-09-2002, 01:17 PM
Veetec's Avatar
Yes, itīs a H22 equiped Prelude!
I also think that the resonator will be in the same location as it is in the US but our side markers are at a different place! How long would somebody who knows the car very well (a Honda mechanic for example ) need to remove it and do I have to remove the butterfly valve, too? Thanx a lot!
Old 02-09-2002, 01:19 PM
Veetec's Avatar
So in other words the Spoon filter isnīt better than the K&N one,right?!
Old 02-09-2002, 01:55 PM
texan's Avatar
Writer Mod
The butterfly valve is part of the resonator, it must be removed and the vacuum line plugged along with the resonator. It took me about 1/2 an hour to remove my resonator, it's not a complex job.
'03 Corvette Z06
'99 Prelude SH
Old 02-09-2002, 02:06 PM
Veetec's Avatar
Okay, thanx for the good info on that!
Old 02-11-2002, 07:12 PM
nope, not at all.
Keep in mind, its just a filter.
Old 02-11-2002, 07:59 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
k n filter flows better, and cleans better than anything on the market... and if spoon flows better/more air, it isnt filtering as much dirt. kn could make it flow more, but it wouldnt be as clean...
Old 02-11-2002, 08:05 PM
Veetec's Avatar
Okay, thanx for all the input!!
K&N Engine Air Filters - Worth It? RidingOnRailz Engineering/ Technical 9 06-24-2011 09:34 AM
K&N Breather for Valve Cover**Brand New** TMO Classifieds 1 06-17-2009 09:47 PM
K&N FIPK or Filter for OEM Set Up rquack Suburban 3 06-25-2006 02:42 AM
K&N replacment air filter tfret Sienna 3 03-06-2006 04:01 PM
K&N REPLACEMENT AIR FILTERS 2k GTP jtwooassoc Grand Prix 7 05-06-2004 07:51 PM
