Old 09-05-2004, 02:12 AM
supratuner89 supratuner89 is offline
Neon underbody
I was just wondering what does everyone else use to make the underbody of cars glow (streetglow, etc.)
I use LED bulbs attached to batteries and then i attach them under the car.
The same question to make the headlights and taillights work.
PS: i always have to connect or disconnect the batteries to turn the lights on and off. where do you guys get switches and how do you wire it or place them or anything related to this subject.
Old 09-05-2004, 02:17 AM
FlySkyline's Avatar
FlySkyline FlySkyline is offline
Send a message via AIM to FlySkyline Send a message via MSN to FlySkyline
Re: Neon underbody
I use LEDs also for headlights, tailights, underglow- and so doesnt all the other people I know. You can get switches at your local RadioShack and maybe hardware stores. They are easy to wire, just stick the ends of the 2 wires into the slot provided or the wires will twist onto posts that are on the bottom part of the switch.
Old 09-05-2004, 02:44 AM
Re: Neon underbody
Thanks alot
It gets really annoying to have to connect the batteries everytime i want to see the lights working
Old 09-05-2004, 02:45 AM
Re: Neon underbody
If anybody else uses a different way please post it i would like to know how you did it.
Old 09-05-2004, 04:45 AM
oi_boy oi_boy is offline
Re: Neon underbody
i bought some LED's a while back, but i forgot to get resistors, anyone know what size i need?
Old 09-05-2004, 09:27 AM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
Re: Re: Neon underbody
Any possibility that someone with expierence with LEDs could post a link or write a tutorial?
Old 09-05-2004, 11:28 AM
stisnan's Avatar
stisnan stisnan is offline
Dinan
Send a message via AIM to stisnan
Re: Re: Re: Neon underbody
I'll make one
Old 09-05-2004, 01:19 PM
FlySkyline's Avatar
You dont really need resistors to run the LEDs. You can run the LEDs straight off the battery (aka cell) but the LEDs or the cell may over heat even if only used for a few minutes. And if you would like to add resistors to the circuit, the amount of resistance depends on what the specs of the LED is, amount of current being used, and how long you would like the LEDs on, so until you know all of those factors you are pretty much stuck with just running them straight off the cell.
Old 09-08-2004, 08:34 PM
Re: Neon underbody
does anyone know where to buy a kit including the cell, resisitors, the LEDs, and anything else needed
online.
Old 09-08-2004, 08:41 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Neon underbody
Buying a kit is going to be hard.
Tonight I was over at my uncles talkin' to him about my hot rod project. He was wiring up some LED's and stuff for his younger son. I asked if he could do mine for my hot rod, he replied "The best way to learn is to smoke a few wires, and fry a few bulbs/LED's". Thats how he got as good as he is.
-Mike
Old 09-08-2004, 08:47 PM
FlySkyline's Avatar
Re: Neon underbody
I tend to take a more calulated way when dealing with the LEDs. Infact we were discussing LEDs in my electronics class today. But I will admit just buying some and trying different things out is a good way to learn, just make sure you got enough wire, it sucks when you just barely dont have enough wire to finish a project
