Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 09-04-2004, 09:02 PM
znfs znfs is offline
Pontiac Sunfire 97 2.4L Engine.
Hello Guys,I am getting ETS OFF light and CHECK ENGINE light on all the time.Got a fault code P0440,which is a malfunction in the EVAP SYSTEM.Can you suggest what I should check or do before taking it to the shop.Thanks.znfs.
Old 09-05-2004, 07:50 AM
crashdummybip crashdummybip is offline
Send a message via AIM to crashdummybip
Re: Pontiac Sunfire 97 2.4L Engine.
Make sure your gas cap is on all the way.
Old 09-05-2004, 01:46 PM
found a previous post about the 440 code. http://www.automotiveforums.com/vbul...d.php?t=232311
Old 09-05-2004, 02:15 PM
I tried retightening the gas cap,but I guess I will have to drive the car until the lights disappear.
Old 09-22-2004, 03:57 PM
jeff51487 jeff51487 is offline
hey dude...im not exactly qualified to be a mechanic...but i did have that exact problem...the solution basically is to take it to the dealer or shop that you got it at unless you find another way. Those two lights were on in my car and the 02 sensor in the exhaust was out....so as the ets is control for the transmission...the toggle switch and the actual ets will be killed in result of the malfunction hope i helped
Old 09-23-2004, 10:15 AM
Hey Jeff,thanks for the info.I was looking at the Haynes Manual and there are 2 O2 sensors,one is mounted in the Exhaust Manifold and the other is mounted in the exhaust pipe after the catalytic converter.I presume you are talking about the one in the exhaust pipe.Please confirm.Thank you.znfs.
Old 09-23-2004, 03:06 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the ets off light is usually an indication that the abs computer has detected a wheel speed sensor out of range, due either to a bad sensor at a wheel, or excessive wheel spin at start.
Old 09-26-2004, 01:21 PM
Re: Re: Pontiac Sunfire 97 2.4L Engine.
to be honest it could be either of these....the manifold could be the problem or the one after the catalytic converter...im not sure of a manual fix because the way i was showed was by a handheld computer board plugged into a port under the steering wheel...this little thing checks all the sensor indications
