Old 08-29-2004, 10:21 PM
FlySkyline's Avatar
FlySkyline FlySkyline is offline
Send a message via AIM to FlySkyline Send a message via MSN to FlySkyline
How To- Flip Flop Trunk
Materials needed
-Diecast model
-Super Glue or Putty
-Cabinet Hinges (I got mine at Walmart for $1.74. The size is 3/4" x 5/8" and they are brass hinges)
-Dremel with cut-off wheel or sanding band
-Screwdriver (Philips)
-Drill with 11/64" or 3/16" drill bit (I used 11/64")
**** You have the option of painting the brass cabinet hinge to match the car. I would recomend painting it by hand****
Remove the chasis and interior to access the trunk hinge. Remove the piece of metal that holds the trunk in the hinge area. Then take the trunk off of the body
Now look at the inside of the trunk, you should see 2 rivets that hold the trunk to the hinge.
They are circled in red in the picture.
Use the drill and drill out the rivets, then the hinge and trunk will be 2 seperate pieces
See how there are posts where the rivets are? Now take you Dremel and grind down the posts so that it is flat with the rest of the trunk
BEFORE
AFTER
Now take the trunk hinge and carefully place a drop of super glue in between the 2 rivet holes (or put some putty there) and then carefully place the cabinet hinge in the middle of the trunk hinge make sure the back of both hinges line up evenly, see pics
If you cant tell what I did, lay the cabinet hinge so it lays flat on a flat surface, then take the trunk hinge and lay it on one side of the cabinet hinge.
Then put the trunk hinge with the newly attached cabinet hinge, back onto the diecast. It should look like this
Notice how one side of the cabinet hinge is attached to the top of the trunk hinge and the other side is flopped over
Now take your trunk and place it back into its original space on the back of the car, it really helps if you tape the trunk in place
Now turn the diecast over. It will look something like this
Look at the cabinet hinge, it should fit right onto the trunk, if not, take your dremel and cut the hinge so it will fit (this was necessary on this CTS). After the hinge fits, take the super glue (or putty) and place it carefully in between the trunk and the other side of the cabinet hinge that is not attached to the trunk hinge (if using superglue, be VERY careful not to lock up the cabinet hinge, this happens by the super glue getting on the 2 pieces of brass that make up the the cabinet hinge). Wait until the super glue or putty dries and enjoy!
Here is the finished modification, along with a few other diecasts I have done this modification on
Here is the Mustang that has the Flip Flop trunk done to both the trunk and the hood
Old 08-29-2004, 10:28 PM
IImportSupra's Avatar
IImportSupra IImportSupra is offline
Send a message via AIM to IImportSupra
Re: How To- Flip Flop Trunk
very good.
Old 08-29-2004, 10:54 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Thats awesome
MAKE ART, NOT WAR
Old 08-29-2004, 11:04 PM
DiecastCustomz DiecastCustomz is offline
Send a message via AIM to DiecastCustomz Send a message via MSN to DiecastCustomz Send a message via Yahoo to DiecastCustomz
Sweet How-To . . .Thanks a lot . . . time to mod hehe.
Old 08-29-2004, 11:05 PM
PETET's Avatar
PETET PETET is offline
very nice. ill try it one day.. cheers
[PROJEKTZ]
Old 08-30-2004, 12:17 AM
tanner07's Avatar
tanner07 tanner07 is offline
That's pretty cool..can you see the brass hinge from the outside or do you have to look pretty close to notice it?
Old 08-30-2004, 12:30 AM
FlySkyline's Avatar
If you look very close at it, or pay alot of attention to detail you can see it. That is why I said it can be hand painted to match the color of the car so it blends in more.
