Go Back   Automotive Forums Car Chat > Nissan > Frontier | Navara
Old 02-07-2002, 07:20 AM
rfowinkle rfowinkle is offline
Angry Why the governor on the engine?
Is there a ligitimate performance mechanical safety reason for having the 95 mph governor on the 2002 Frontier? Or is this a government consumer safety thing?
Old 02-21-2002, 12:06 PM
cybercrx00 cybercrx00 is offline
Send a message via AIM to cybercrx00 Send a message via Yahoo to cybercrx00
it's so you don't flip your ass over and die
Old 02-21-2002, 12:33 PM
spnx's Avatar
spnx spnx is offline
LOL!
Concise, accurate, and to the point
Old 09-28-2003, 07:57 PM
nikepenguin nikepenguin is offline
can you remove it and if yest how
Old 05-03-2004, 05:04 PM
Nissan_Nismo's Avatar
Nissan_Nismo Nissan_Nismo is offline
Send a message via Yahoo to Nissan_Nismo
Re: Why the governor on the engine?
you can remove any governer it just takes time and knowledge ill look it up for you cause i am going to do it too...
ill email you instructions when i get the time
Old 05-27-2004, 08:12 PM
frontier driver frontier driver is offline
why in the hell would you want to go over 95 in a frontier? i see a frontier doing cartwheels with u as the driver.
Old 05-28-2004, 12:26 PM
Re: Re: Why the governor on the engine?
LOL, i completely agree IF YOU DO NOT KNOW HOW TO DRIVE AT 95 OR HIGHER then dont but for those of us who actually can drive and dont freak out doin 90 should be able to, or at least on the track
Old 05-28-2004, 02:00 PM
deadmaninc deadmaninc is offline
Dont you need to just get the ecu re-programed? Which engine do you have? I read the 4cylinder tops out at around 100.
Old 06-27-2004, 04:35 PM
blackknight03 blackknight03 is offline
governors are used usually to keep your speeds under the speed rated on the tires. for trucks though it's ludacris for it to be governed at 95... 105 or 110 would be fine but there have been times I need to pass on a two lane road that the speed limit is 70 and as i'm in the opposite lane trying to pass in a short distance the governor kicks in! the main thing that bugs me is how abrupt the governor is in the frontier. usually all other cars the governor is much more "svelte" at kicking in. An ECU reprogram is the only way to rid of it though!
later,
Old 08-18-2004, 05:31 AM
TUFFRTOY TUFFRTOY is offline
Angry Frontier governor
I sure found out the hard way as well about the governor. I was passing another car when it kicked in at 90mph, thought something was wrong until!!! I gotta find a way around that!!!!
Old 08-19-2004, 04:34 AM
How do I get an ECU reprogram to rid of it?
Old 08-24-2004, 08:46 PM
Paul Burkhardt Paul Burkhardt is offline
Is this a rpm governor in all gears or just a top end gov.
Old 09-03-2004, 03:50 AM
All I know is that around 90mph, it like dies until it's slown down to aprrox 85mph then it's all fine again. The rpm and acceleration totally dies at 90mph.
Old 09-19-2004, 09:40 PM
Frontin' Frontin' is offline
Send a message via MSN to Frontin'
getting rid of the gov is simple but does cost. you can buy something like a superchip which is a well known brand or something. have the chip installed and tell them to reprogram the gov. really its still there but they can set it at like 150 or something. im sure u can do it with the stock ecu too but shit, buy a chip it adds hp and its all around a better way to go
Old 09-21-2004, 03:14 PM
it depends on what truck you have. usually ou have to buy a reprogrammer yourself for the newer ones since most places wont' mess with it. (works like a chip in older cars) but those usually run anywhere from 600-1500 bucks. the best you can do is just plan passing accordingly and just live with the fact that you can do 100 out on some desolate road while traveling (like I like to do)
later,
Why did the Dodge 318 engine lose 80 hp and 60 torque from '71 to '72? C/PO1 Schneider General Discussion 7 01-20-2010 09:24 AM
2002 Frontier - governor on engine rfowinkle General Discussion 2 02-21-2006 02:18 PM
Why Was The 95 Blazer Engine Junked In 96?? Rick1488 Blazer 5 01-31-2006 09:14 AM
Why does Starter turn engine when I try to connect the negative cable to battery. elevator Century 2 07-16-2005 02:29 AM
