Old 02-06-2002, 11:12 PM
T.O.tegs T.O.tegs is offline
paxton in-line fuel pump...
paxton external fuel pump.....yes or no
I have a chance to buy this fairly cheap...is this too much for N/A...
engine is basically B20B short block/GSR(P72) head.....running about 12.8:1 compression...
rest of fuel system is AEM fuel pressure regulator, AEM fuel rail, RC 310cc injectors, dual fuel feed to fuel rail/two fuel filters and braided stainless lines all around...
msd 6al/dis. cap/wires/blaster 2 coil and denso plugs would be doing the sparking...
any opinions about this in-line pump would be appreciated:smoker:
WUTS DAT
AF nordic #7 foo...you better recognize:finger:
Old 02-06-2002, 11:45 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
paxton makes good stuff from my prior experiences... just make sure the pump you're looking at is a high volume pump for EFI (90-130 psi) pump and not a carburetor pump (8-30 psi)
Old 02-06-2002, 11:54 PM
texan's Avatar
texan texan is offline
Writer Mod
What's the LPH or GPH rated flow of the pump? And do you know what the rated flow is at the fuel pressure you're running? If this is a race car this might be a viable option, if it's a street car I highly recommend against inline pumps. Fuel pumps (especially the big flow external pumps) are actually quite loud, which is why no factory car places them anywhere except in the fuel tank. At stock fuel pressure settings it's easy to get an inline pump that'll flow to 500hp.
'03 Corvette Z06
'99 Prelude SH
Old 02-07-2002, 09:15 AM
yea, it's for fuel injected...
this is for my daily driver....I know that the pump will be whining all the time but I'm willing to live with it...I'm actually planning to mount it in the engine bay.....I'll post up some pics soon
WUTS DAT
Old 02-07-2002, 10:56 AM
texan's Avatar
Writer Mod
ALWAYS mount your fuel pump as close to the tank as possible.
'03 Corvette Z06
'99 Prelude SH
Old 02-07-2002, 11:37 AM
I always see this pump mounted just below the rear bumper...I'm just worried some one will try and rip it off
WUTS DAT
Old 02-07-2002, 11:46 AM
texan's Avatar
Writer Mod
Well look, why don't you explain why you are so hell bent on buying this pump in the first place? There's absolutely no real reason to do it, but you seem almost definite on buying it. Why?
'03 Corvette Z06
'99 Prelude SH
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
installing in-line fuel pump localyokel C/K 1 02-14-2006 07:49 PM
