Old 02-13-2006, 06:50 PM
localyokel localyokel is offline
installing in-line fuel pump
Anyone have any tips/suggestions on installing an in line fuel pump on an 85 p/u.The mechanical pump works perfectly in hand,not on the v6.Assuming the cam that pushes the rod is no longer oblong.this truck also has dual tanks.Any thoughts?
Old 02-14-2006, 07:49 PM
Arrowshooter Arrowshooter is offline
Re: installing in-line fuel pump
I'm assuming that the rod moves freely in the hole? You have two options with the duel tanks. One is to mount a single pump right after your inline tank switching valve. Second, which I prefer, would be to mount two pumps one right at each tank. Then a three-way switch on your dash to opperate each pump independently. Good luck.
