Old 02-05-2002, 11:57 PM
996GT2 996GT2 is offline
Send a message via AIM to 996GT2
Changing the drivetrain
Does anybody know of anyone who's converted a FWD car to a RWD?
If so, how much did it cost (roughly)?
I would imagine that a tunnel would have to be made that protrudes into the cabin in order to make clearance for the new driveshaft (among many, many other things of course).
How will this affect spoon engine installations?
Thanks.
I love Porsche!
http://911turbo.s5.com
Old 02-06-2002, 07:25 AM
SaabJohan SaabJohan is offline
It can be done, but it's expensive and difficult.
The engine is mostly mounted diffrent in a FWD car than in a RWD, this can be changed but you will need new mounts (maybe you must adapt the whole enginebay for the new engine setup), and a new gearbox. You must also remove the driveshafts to the front wheels and change many of the parts in and around the front hubs (maybe new hubs and suspension).
Then you must have a rear diff and driveshafts, and of course a driveshaft to the rear wheels. You must probably change the most of the rear suspesion. A bigger tunnel for the driveshaft can also be needed.
Then I think it's smarter to convert to 4WD. Gearbox and diffrentials you can use from an Audi S2, or if you want a little better system you can buy Prodrive gearbox and diffs.
Old 02-06-2002, 06:00 PM
texan's Avatar
texan texan is offline
Writer Mod
What car are you considering doing this on? How much sense it makes and how much it would potentially cost depends completely upon the application.
'03 Corvette Z06
'99 Prelude SH
changing headlight system from sealed beams to just changing the bulbs candywrapper Grand Prix 2 07-26-2009 10:39 PM
Vibration and noise in the drivetrain gc30736 Tacoma 1 07-20-2007 01:50 AM
Changing the drivetrain fluids. Polygon 3000GT/Stealth 13 11-06-2006 01:27 AM
'92 4x4 with a Whine in the drivetrain superfly_32 Pick-Up 0 04-29-2005 11:38 AM
how do i change the lights in the termostat of the car ice_rr '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-23-2003 12:27 AM
