Old 11-03-2006, 03:00 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Changing the drivetrain fluids.
I need to change the fluids in my tranny, t-case, and rear diff. I was going to get RP until I read a thread at 3Si:
http://www.3si.org/forum/showthread.php?t=353085
So that got me wondering what I should do. I want to go with Redline now and here is what I have picked out:
Transmission: http://store.summitracing.com/partdetail.asp?autofilter=1∂=RED%2D50304&N=700+400 236+4294872961+115&autoview=sku
T-case/Diff: http://store.summitracing.com/partdetail.asp?autofilter=1∂=RED%2D57904&N=700+400 236+4294872961+115&autoview=sku
What do you guys think. Do you have any other suggestions?
Old 11-03-2006, 03:58 PM
AutostradaVR4 AutostradaVR4 is offline
Re: Changing the drivetrain fluids.
i put BG Synchroshift II in my tranny and transfercase and if feels like a brand new tranny. All the notchy feeling is gone. I havnt used redline or royal purple, but from my experiences with BG, im definitely gonna stick with it.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 11-03-2006, 04:20 PM
Polygon's Avatar
The Red Baron
Where can I get the BG Syncroshift? I tried looking for it on Summit but they don't have it.
Old 11-03-2006, 05:29 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
3sx sells the BG stuff, i believe.
ya, i read that thread on 3SI about Royal Purple. bull crap. half the guys that posted said they disagreed with the thread starter. even the thread starter said he made a premature judgment, and admitted that he doesn't know jack about transmissions, adn that it was most likely an totally unrelated problem causing the rattling.
whatever, i don't care. you can't please everybody. ppl who bad-mouth a product always seems to make more of a negative impact than someone who praises that same product.
i've been running RP in my transmission for a 4,000 miles and i'm very happy.
plus, you can pick up RP at any NAPA auto part stores. as for BG...probably only find it online, then you have to pay shipping.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-03-2006, 05:32 PM
Igovert500's Avatar
blue + red light magnet
I believe i used mobil 1 synthetic 75w90 for hte rear diff, and penzoil synchromesh for the transaxle, I can't remember which of the 2 i used for the t-case...I wanna say it was the synchromesh though. Shifting was noticeably improved, and no problems to date. ~14k
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-03-2006, 05:48 PM
i buy mine from GT Pro...
http://www.gtpro.com/productshow.cfm...model2=Stealth
they get $12 a bottle and youll need 3 for trans and Xcase. If you look hard enough im sure you can find it for less, but its nice to give the business to a fellow 3/s enthusiest IMO.
Formerly BlinkRA182
Old 11-03-2006, 08:15 PM
Polygon's Avatar
The Red Baron
The only reason I am second guessing RP is because my transmission grinds. I will need new syncros eventually, but I want to do whatever I can to prolong that. The ONLY comment that concernes me was the one about Kormex not liking it. I can't belive the BG is that expensive, $36 plus shipping. Also, one of the reasons I posted this thred was to get some different points of view because I was watching Hot Rod TV last week on Spike and they had a special on RP and I was VERY impressed to say the least. Like I said, the only comment I paid attention to was the one about Kormex.
Anyhow, I guess I'll go down to NAPA and give the RP a try. It can't be any worse than what's in there and who knows if it has ever been changed.
Old 11-03-2006, 10:19 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
I run Mobil 1 Synethic 10W-30 in the tranny and Mobil 1 75W-90 in the T-case. No grinding/notchyness. Just smooth, easy shifts .
I ran the Mobil 1 75W-90 in the tranny before I switched to 10W-30 and it was very notchy and grinded 3rd sometimes.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 11-03-2006, 11:40 PM
Linebckr49's Avatar
Royal Purple also makes a Synchromax gear oil fluid/additive. you might toss 1 qt of that in with the other 2.X qts of 75w-90 RP. that might better aid in your current grinding.
93 3000GT base
Old 11-04-2006, 09:29 AM
Igovert500's Avatar
Anyone running Redline ShockProof or whatever it's called? Been thinking of giving that a try next time around.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-04-2006, 02:31 PM
Polygon's Avatar
The Red Baron
Here is what I was thinking of getting:
Transmission: http://store.summitracing.com/partdetail.asp?autofilter=1∂=RPO%2DRP01512&N=700+4 294925094+115&autoview=sku
T-case/Gearbox: http://store.summitracing.com/partdetail.asp?autofilter=1∂=RPO%2DRP01300&N=700+4 294925094+115&autoview=sku
So, mix a quart of Syncromax with the 75x90 in the transmission. Do I put the Syncromax is the t-case as well, or just straight 75w90?
Yeah, I was looking into that and Summit's site said that it should only be used for race applications. However, I know someone that is running it on 3Si and he seems to like it.
Old 11-04-2006, 05:00 PM
ricebike ricebike is offline
to add, i just saw pepboys selling 3 kinds of royal purple stuff as well!
if you also have an advance auto parts store (or something similar) a la www.partsamerica.com as the reference if you're living out west & dont have an advance auto parts store in the area...
you can actually go into the store and special order Redline-w/out paying shipping fees- from their "warehouse" & do an in-store pickup when they receive it!
Old 11-05-2006, 06:58 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
I don't mean to steal your thread but I have questions now.. what different fluids should you use? what can you use? twizted said he is useing 10w 30? for the tranny.. mitsubishi says use 75w85 I believe.. and just wondering do you add Synchromax to the tranny or the Tcase or bolth? What about limited slip as part of the options in the red line.. do i just put that in the rear end?
Old 11-06-2006, 01:27 AM
Mitsubishi says 75W-90 for the tranny, but they got it wrong. Getrag says 10W-30 Synthetic, call them on it.
