Old 02-05-2002, 10:18 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
Exclamation Engine Wash?
Hey, I have a question. If I wanted to clean under the hood of my car, is there anything that I should do besides take a high pressure sprayer to it? Do I benifit anything from doing this or is it just for looks? (If I dont ever clean it out, will it effect anyhting?)
Thanks!
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 02-05-2002, 10:38 PM
Someguy Someguy is offline
Send a message via AIM to Someguy
I wouldn't use a high pressure washer. Things are fairly water-proof, but there is quite a bit of electronics under there. I'd go for more of a careful hand wash.
Benifits? It looks better. May be easier to track down leaks in the future. That's all I can think of off hand.
Old 02-05-2002, 11:24 PM
89ssgti's Avatar
89ssgti 89ssgti is offline
plus the engine might run a little cooler and your mechanic will like you cause he won't get all dirty working on your car.
You could spray some engine cleaner or engine shampoo on first for better results.
And put plastic bags over the distributor cap.
Proud member of AF's Lazy crew
Snow,snow let it snow
Af Nordic crew #008
team drift cat official member#5
Originally posted by sparq
CANADA RULES :finger:
CANADA RULES -- thats all that matters :ylsuper
Old 02-06-2002, 09:50 AM
FLAWLESS FLAWLESS is offline
Send a message via AIM to FLAWLESS
Just to be safe you should cover all electrical/ignition stuff with plastic (saran wrap) and rubberbands, wash it by hand later. Getting it wet can decrease life. Don't worry about all the little electrical connectors, just the major ignition stuff.
Spray Simple Green all over the engine, use a brush and scrub all over, incl. the underside of the hood, and rinse thoroughly, using as little water as possible if that makes sense. Simple Green is a good degreaser that won't harm your paint.
When you're done, drive for 20 min or so to help dry it off. Then use some rubber dressing (like armor all...I use Meguiar's Shine) and wipe down all the hoses and rubber stuff. You'll love the results!!!
98 Civic LX - Bottle-Fed
Old 02-06-2002, 08:43 PM
Integra-F20C's Avatar
Integra-F20C Integra-F20C is offline
Send a message via ICQ to Integra-F20C Send a message via AIM to Integra-F20C
hmm..one small question guys, should the battery be covered or taken out?..or just leave it there and clean and dry it with cloth later on?
97 JDM Accord SiR-T
more infoHere
Old 02-06-2002, 09:03 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Actually I will try to disconnect the ground (B-) cable from the battery before doing all that stuff (make sure you know your radio code and other electronic that it might affect), then after everything is done and wipe dry, wait for a while or over night to dry with open hood (just to be safe) before driving.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
no start after engine wash lilol89crx Off-Topic 9 02-01-2004 05:02 PM
engine washed, now i got issues. lol SmoovSol Engineering/ Technical 13 10-19-2002 02:53 PM
engine washed, now troubles come.. help SmoovSol '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 10-18-2002 07:01 PM
engine washed, now i got issues. lol SmoovSol Engineering/ Technical 0 10-17-2002 07:26 PM
Engine wash - howto Devedander '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 02-16-2002 02:12 AM
