Old 08-17-2004, 02:37 PM
fordforlife's Avatar
fordforlife fordforlife is offline
big block 460
will a 460 bolt up to a small block stock tranny? thx!!
Old 08-17-2004, 04:57 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
With the right bellhousing it will.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-17-2004, 05:52 PM
Re: big block 460
the engine comes with a c6 tranny, should i just put the whole thing in there? If not, what kind of bellhousing would i need?
Old 08-17-2004, 10:34 PM
GTStang's Avatar
Stang Guy
I'd use the C-6 makes life a lot easier. Unless there is a big reason you don't want to use a C-6.
Old 08-18-2004, 01:40 AM
motor_head_429 motor_head_429 is offline
Re: big block 460
Just wondering, what is this 460 going in?
Old 08-23-2004, 09:13 AM
Re: big block 460
im putting it in a bronco, reason i asked in here is it always takes a while to get a reply in the bronco forum, and i fig people with older mustangs would know about big blocks, so thats why i asked in here. thx for all your help by the way. My uncle came across a 302 with 60k miles and i bought it for 500. Its out of a lincoln mark 7 i believe. I just have to decide if i want to run fuel injected or carb I have the harness and pc.
Old 08-23-2004, 10:39 PM
rerun rerun is offline
if you plan to do any steep hills or anything go FI. i like carbs a lot better for older street cars, but not for that type of stuff.
Old 08-23-2004, 11:48 PM
I agree, for off roading I would also go with fuel injection. I asked what you were putting it in because there was one guy at the track that had a fox mustang with a 460 and a 300 shot. Brings tears to your eyes doesn't it?
Old 08-24-2004, 12:32 PM
Re: big block 460
a friend of mine was saying that a carb would be better for off road because electrical stuff and water/mud dont get along all to well I dont need it to have great mileage, hell, its a bronco! Why do yall recomend FI for offroading?
That redefines the term...."more power."
Old 08-24-2004, 12:58 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: big block 460
Carbs can't be tilted too much, otherwise the fuel won't get to the jets and therefore the engine. Fuel injection doesn't care whether its right side up. If you are going to be doin serious offroading, consider fuel injection or propane injection. If not, then you can just as easily go with a carb and have no problems. If you don't expect your bronco to be at any extreme angles, I wouldn't worry about it.
Old 08-24-2004, 03:45 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: big block 460
better hope he is running boost if he is going to inject propane. propane will give the same affect as injectiong Alcohol into the engine. If you don't have the compression to maintain a flame with that cold of an aircharge, then all it is going to do is sputter and backfire.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 08-24-2004, 07:09 PM
Re: big block 460
I gotcha. Yall wouldnt know of any webpages on making wiring harnesses would ya? I have the wiring harness from the 302, but i have to make it fit my bronco, so i need some webpages/info on how to combine the two. Any help is greatly appreciated!!!
Old 08-24-2004, 07:24 PM
Re: big block 460
or do i have to combine the two? can i just run the wiring harness that goes to all the engine stuff, or do i need the other wiring harness that went to the lights and god knows what else, lol. I pulled that off the car also just incase. The whole reason i was leaning towards a carb is because ive never tried to hook up FI on a carb'd car, so i would need some info It doesnt seem too hard as long as i take my time and match everything up.
