Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-05-2002, 02:57 AM
hondatool hondatool is offline
Exclamation steering and swerving problems
sometimes when im driving at the road is bad or kinda wavy an uneven my tires will turn suddenly or something my steering wheel will shift to the left or right pretty good...what is this and what can i do to fix it?...alignment?...by the way im riding on 17 inch kumhos 205/40/zr17 with enkei cdr9's if that makes a difference
Old 02-05-2002, 02:28 PM
texan's Avatar
texan texan is offline
Writer Mod
Yes, first you need to have your alignment checked. Make sure you get a printout of the alingment specs before and after, and save that for possible reference in future replies to this thread. Also check that your tire pressures are identical from right to left on each axle, and are you having any directional instability under braking?
'03 Corvette Z06
'99 Prelude SH
Old 02-05-2002, 02:46 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
It's pretty normal with larger wheel/tire packages. The wider contact patch will catch uneven things on the road. But yes make sure you get an alignment at least once a year or every two years. And then make sure pressures are event at every corner.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 02-07-2002, 01:27 PM
twizzaut's Avatar
twizzaut twizzaut is offline
if ur car is lowered then make sure u have a camber kit on there!! make sure ur toe-in is correct too
HöÑÐã§ 4 Lïƒê
Old 02-07-2002, 01:54 PM
Someguy Someguy is offline
Send a message via AIM to Someguy
My guess would be the toe is a bit out, but its hard to tell. Wider tires will tend to want to follow grooves in the pavement more, as well a bumps, but your tires aren't all that wide. Get an alignment.
Old 02-07-2002, 03:14 PM
Civic Mod
You don't need a camber kit unless you are dropped more than 1.8"
Autocross Help Page
Buy my Civic parts!
Old 02-07-2002, 05:24 PM
HybridKidd HybridKidd is offline
Do you need a camber if you have a 1.8" drop exactly..i do...sportlines
.: 00 Civic EX :.
-Eibach Sportline
-carbon fiber gauge cluster
-AC strut bar
-CTR shift knob + grill
Old 02-08-2002, 12:39 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
First check the alignment...i had the same problem with mine about the swerving and all and i got an alignment and it helped it out alot.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 02-08-2002, 07:07 PM
cool thanks...
Engine, Power steering, and smoke problem. 4run4x4 4Runner/GX470 2 02-26-2007 06:43 PM
Steering and Transmission Problems stevio27 Engineering/ Technical 6 01-22-2006 11:48 AM
power steering and brake problem william Diaz M Bodies 2 01-27-2005 12:45 PM
Steering and performance problems forum99 Accord/TSX/Accord Hybrid 2 01-14-2004 03:37 PM
