Old 12-20-2004, 12:42 AM
william Diaz william Diaz is offline
Angry power steering and brake problem
About 3 days ago i put my astro on reverse and the steering whent completely hard and the brakes where hard to press down and were not baking wright. I checked the power steering fluid and it was empty.I replaced the fluid and turned the steering wheel about 15 time and still its hard to steer what should i do.
Old 12-20-2004, 06:44 AM
CD Smalley CD Smalley is offline
Re: power steering and brake problem
Sounds like the hydroboost unit has failed. This unit is used to generate the brake boost, like a vacuum booster on other cars. It is ran by the power steering fluid. It could also be a failed pump, but given the sudden nature of the failure....
Can you see where the leak is at??
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 01-27-2005, 12:45 PM
jtb74168621 jtb74168621 is offline
My powersteering pump quit working while in the shop. What happened in this case was the pump shaft broke. It cost me about $350 if I remember correctly.
