Go Back   Automotive Forums Car Chat > Honda > RSX
Old 08-15-2004, 03:14 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
Question Rsx Faq Post Here
Seeing as there have been many repeated questions/threads, here is a thread just for those types of posts.
I'll leave it open to the "RSX regulars" to bring up any questions they feel are asked too much.
Hope this helps...
-KrNxRaCer00
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 08-15-2004, 11:31 PM
cartoys21's Avatar
cartoys21 cartoys21 is offline
Re: Rsx Faq Post Here
1. What upgrades should I get for my RSX?
2. Does anyone else get gear grinds when shifting?
--2002 Acura RSX-S--
STOCK
HOWEVER, coming soon.....ah, who am I kidding, nothing.
Old 08-16-2004, 06:55 PM
crazy_canuck crazy_canuck is offline
I don't have gear grinds and all that crap, so i'll just say this: There are tons of petitions out there are you aren't the only.
For the performance question:
Naturally Aspriated (no turbos/superchargers/NOS) the cheapest and best all around gain is:
-Injen CAI (intake, submerging the filter will cause the engine to seize, that is very rare, however)
-Hondata (ECU upgrade to change VTEC points, redline, etc.)
-DC5R rear sway bar (virtually elimates understeer)
-Race Headers (illegal becuse there won't be a cat conv.)
-Springs (tons of them out there with different heights and stuff)
-Hondata Intake Manifold Gasket (cheap and give a little bit of a gain)
Exhausts on the RSX will only really give looks and sound differences, not performance
Turbo:
Two major kits out there, GReddy and Cybernations. The GReddy isn't upgradeable, the Cybernations is upgradable to 700whp should you be that daring/insane. Get the Cybernations as it is slightly more expensive but offers a lot more expandability and customization.
Supercharger:
Jackson Racing is the only one with a SC for the RSX so far, although in less than a month we should see the Comptech (which will be warrantied by Acura if the dealer does it).
Get a turbo as its more expandability, much cheaper for the power, and as long as you don't put a jillion pounds of boost, it'll be about as reliable as a SC.
Old 08-23-2004, 12:47 PM
RSX-S777's Avatar
RSX-S777 RSX-S777 is offline
The "gear grind" many people are experiencing is due to the slight catch experienced when shifting from second to third in the RSX Type S. This transition involves shifting from triple cone synchros in second gear to double cone synchros in third. For some reason this transition is not as smooth as it should be. Although Honda denies any and all responsibility, this problem is far too widespread to be coincidental. As Canuck said, you can sign one of many online petitions, although it is not likely to bring about any changes. There is nothing "broken" per se, and therefore nothing your dealer can do to fix the problem. They will most likely deny there IS a problem to begin with. There have been sporadic reports of this problem occuring in base model RSXs, but not to the degree we have seen in the S.
I've got a fever. And the only prescription is more cowbell...
Old 09-30-2004, 06:13 PM
Please move to the RSX forum.
Old 10-19-2004, 04:16 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Re: Re: Rsx Faq Post Here
Done.
Resistance Is Futile (If < 1ohm)
Old 10-19-2004, 04:51 PM
Thank you.
Old 10-24-2004, 03:14 PM
haha suckers! I'm not feeling gear grind anymore!
Old 11-24-2004, 11:42 AM
Mendari Mendari is offline
This link is provided by ClubRSX.com.
Acura Service Bulletin (i.e. Recall) for Gear Grind.
Old 05-14-2005, 11:33 PM
paulkramer paulkramer is offline
Huh?! What's your secret, Canuck? I have to tease my damn trans into 2nd to avoid that nasty grind.........
Old 05-15-2005, 12:08 PM
sivic02's Avatar
sivic02 sivic02 is offline
I had some grinding issues and this seemed to work for me, I still get an occasional slight grind but its greatly reduced. Its on a si but it should be the same.
http://www.ephatch.com/forum/showthread.php?t=54322
Here's to being single, seeing double, and sleeping triple
Old 05-16-2005, 01:45 PM
Hmm....thanks for the tip.......I will check it out, though I don't think there's much room to play with from the feeling I get with my clutch pedal. That is, it starts to "clutch" almost as soon as I put any pressure on the clutch pedal.
Old 05-20-2007, 09:01 PM
Repsol69 Repsol69 is offline
Would a flywheel be a good investment on an RSX?
Old 05-20-2007, 10:30 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Mated with a good clutch, yes.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 08-14-2007, 05:36 PM
ZRYDERVR4's Avatar
ZRYDERVR4 ZRYDERVR4 is offline
what problems does the 1st gen have that the second gen does not have? ( if there is any)
Are they an easy fix if it does have some?
Originally Posted by BlinkRA182
Basically, just choose on looks.
Originally Posted by Morphius289
Well, if that's the way people choose between 3000's and Stealths, than we wouldn't have any need for Stealths, would we?
