Old 08-15-2004, 11:43 AM
andrewespo's Avatar
andrewespo andrewespo is offline
Ford Racing GT-40 Intake Manifold
Im thinking in investing into the GT-40 intake manifold. But before I do Im wondering if this mod calls for a mass air conversion, or I can still milk the speed density? (88 GT)
http://static.summitracing.com/globa...m6001a50_m.jpg
Old 08-15-2004, 01:46 PM
90Stangjc 90Stangjc is offline
I believe unless you change your heads/cam that u shouldnt have to convert to mass air. I think speed density can handle minor mods and even the intake manifold. Maybe you should do mass air anyways, be great in the long run.
1999 Camaro Z28 M6- Aftermarket mods- LS6 Intake, Chip
Home mods - Ram Air mod, !CAGS
FACTORY FREAK BIOTCH!
Old 08-15-2004, 01:59 PM
andrewespo's Avatar
I was going to convert, buts its like $550. The GT-40 intake manifold is $600. I have $600 to spend its basically a toss up.
GT-40 intake manifold = Horsepower
Mass air conversion = Allows me to make the major upgrades down the road.
What would you go with? Mass air still?
Old 08-15-2004, 03:26 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
first off, you can find a gt-40 manifold and often a cobra intake to go along with it for much less than that on ebay. i'd upgrade to mass air first anyway.... it'll prepare you for your other mods.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 08-15-2004, 04:24 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I would not get a GT-40 intake unless I got an awesome deal. There are many intake manifolds that are far superior for equal or less money.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-15-2004, 08:11 PM
wildstringer's Avatar
wildstringer wildstringer is offline
Re: Ford Racing GT-40 Intake Manifold
I also have speed density on my mustang. I have been told hat with speed density the computer will adjust air and fuel back to factory specs . so if you add more with a better intake the computer will null out the changes. now with MAF the computer will recalibrate after all changes. just disco the battery and it will allow the computer to acccept add ons. not to mention i ve been told idle quality is better with MAF
Old 08-15-2004, 09:01 PM
andrewespo's Avatar
Can I find a cheaper mass air conversion kit. The one on summit is expensive.
Old 08-15-2004, 09:06 PM
andrewespo's Avatar
Which ones are superior for less or equal price specifically?
Old 08-15-2004, 10:47 PM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
Re: Re: Ford Racing GT-40 Intake Manifold
the trick flow track heat manifold $425 @ crmotorsports.com
and i would go for MAS first too.
Old 08-15-2004, 11:31 PM
andrewespo's Avatar
Is summit the only place to pick up the Mass air conversion?
Old 08-16-2004, 01:36 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Yeah Trick Flow is nice one. I have the track heat and am thus far pleased. MAF conversions are carried by many companies, summit usually has the best deals on parts though. Most of my entire car is summit bought.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 08-16-2004, 09:02 AM
GTStang's Avatar
Stang Guy
No this is not how SD works. SD will adjust to changes by performance parts. Here are the 2 problems with SD: 1. It can only change within stock pre-map variatons. 2. It can not handle mods which would cause large lamda in manifold pressure.
As far as better/superior intake manifolds. Hell the Cobra intake manifold has been tested and only flows 1 cfm less than the GT-40 and can be purchased for half the price. I don't even like the Cobra but it just goes to show how overpriced the GT-40 is.
Old 08-16-2004, 02:46 PM
andrewespo's Avatar
What about the trick flow EFI Street intake manifold? The track heat one would need a cam too go along with it right? Also the idle is 1500 -6500 rpm on the track heat what does that mean.(idle is no lower than 1500 and no higher then 6500?
Old 08-16-2004, 10:14 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Get the explorer intake, same as Cobra/GT-40, just doesn't look quite as cool. Never over 300 bucks, though.
BTW GT-40 and Cobra intakes are internally the same...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 08-16-2004, 11:37 PM
if you can find a junkyard mustang you could salvage the needed parts from it . but i ve read the process for conversion and its a little tricky so you will want directions . i was gonna get mine from summit too. there was this one place that had one for 626.00 but that came with 24# injectors and of course the meter was calibrated for them .The place is called excessive motor sports ExcessiveMotorsports.com or 1-800-930-9585
