Old 08-14-2004, 10:26 PM
NailZ69's Avatar
NailZ69 NailZ69 is offline
Send a message via AIM to NailZ69 Send a message via MSN to NailZ69 Send a message via Yahoo to NailZ69
Bah =/
im having a problem with the new maro i bought...i need exaust pipes from the cat back..let me know if u have any..
..and the problem is.. when u start it and drive then go to turn it off it sptters like it wants to keep running..sometimes it does it once or twice..and sometimes it acts like its not gonna stop...whats causing it to do this? how do i fix it?
thx,
NailZ
[]D [] []\/[] []D [] []\[]
"If you see my car on a trailer.....It's STOLEN~!"
Old 08-14-2004, 10:32 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: Bah =/
well the sputtering is dieseling....my truck does that sometimes. someone told me how to fix it but honestly i forgot.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 08-15-2004, 12:28 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
The problem is called dieseling and it is usually caused by your timing being off. Try setting your timing agian. And this time use a timing light! LoL
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-15-2004, 12:51 AM
hellraiser319's Avatar
hellraiser319 hellraiser319 is offline
Registered User
Re: Bah =/
what kind of engine and intake system (carb, tbi, tpi, etc)? could be timing or it could be running overly rich. i have an 84 with carbed v8 and the choke thermo was dead and would always stay closed and when it was warm it would always do that when you shut it off cuz of it bein rich from choke bein closed.
Old 08-15-2004, 01:18 AM
4onFloor's Avatar
4onFloor 4onFloor is offline
dieseling also happens when your engine runs too hot, but you usually only on carbed engines. assuming this is carbureted, what happens is, the pistons and combustion chamber get so hot that after the key is turned off and as the engine winds down, it's still pulling gas from the carb, then the fuel ignites on contact as it hits the combustion chamber
Old 08-15-2004, 04:06 AM
NailZ69's Avatar
Re: Bah =/
so what do i do to fix it?
Old 08-15-2004, 07:51 AM
osucordell's Avatar
osucordell osucordell is offline
Re: Bah =/
dieseling could be caused by a number of things. Your idle speed could be set too high, timing off, overheat (check thermostat, radiator, water pump if that's the case),solenoid at the side of the carb could be fucked up.
I'd say just start checking these devices and see if you can't figure it out, if that doesn't work then I have another idea but it's a long shot.....
Old 08-15-2004, 09:38 AM
NailZ69's Avatar
Re: Bah =/
well i know it's not overheating..so go ahead and cross that out
Old 08-15-2004, 10:36 AM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
someone told me it was from too low of octane when i was running 87 so now im running 91 (too cheap for 93 still lol) and it only does it to me once in a while now and only a quick spudder
Old 08-15-2004, 07:52 PM
NailZ69's Avatar
Re: Bah =/
well when i fist bought it..i filled it up with 93 for $31 something and got 18gallons..it didnt do it..now for the past few days i HAVE been running 87....maybe thats my problem
Old 08-15-2004, 08:26 PM
NINÅ's Avatar
NINÅ NINÅ is offline
Re: Re: Bah =/
Run-on can be can be caused by carbon build-up.
I had the same symptom with my 78. I inadvertantly repaired the problem one day when my thermostat stuck closed. The overheating (300
*) caused it to want to stall, but because I have a "refuse to lose" attitude I kept my foot in it. The high temp and nitro type rattling caused a large cloud of carbon smoke to exit the exhaust. From then on the problem ceased.
Old 08-16-2004, 12:19 AM
Registered User
Re: Bah =/
normally if your engine is basically stock, you should run 87 or 89 tops. if you advanced the timing or did headwork or anything else that needs higher octane, then go and use the 93. 93 on the stock engine isnt good for it cuz its set up to accept the lower octane fuel, in accordance with emmissions regulations crap. thats all i can remember for now
Old 08-16-2004, 09:21 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Bah =/
go with a higher octane, that sounds like the problem. but like hellraiser said, it shouldnt really NEED the 93 unless its been toyed with. i would look into where the timing is and maybe carbon build up on the pistons...
*Better power-to-weight ratio than a C6 corvette*
Old 08-17-2004, 09:07 PM
NailZ69's Avatar
Re: Bah =/
i dont feel like calling my mechanic for such a stupid problem, i just put higher oct in it and it hardly does it anymore so i'll leave it at that..
..besides that fact im getting some police series flowmasters tomorrow!!! i found a 3rd gen cop camaro with all the mods abandond so im taking everything from it >=)
Old 08-18-2004, 09:43 AM
Re: Bah =/
they made a third gen pursuit camaro??
