Old 08-14-2004, 05:12 PM
Lotus49 Lotus49 is offline
Send a message via Yahoo to Lotus49
ANother problem. a LRAGE Power loss
driving home today, i tried to get on it.. i have absolutely no power. It took me at least 10 seconds to reach 60. Also , then engine note has changed alot. i dont understand what this problem could be. I checked for the cat being clogged with a temp gauge. Off the manifold its 900F, before the cat its 750f and after the cat its 774f.
Old 08-14-2004, 05:43 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: ANother problem. a LRAGE Power loss
is there a check engine light on?
Old 08-14-2004, 06:53 PM
no, there is no check light.. ive done a tune up on it already. A new opti, plugs wires, fuel filter, o2. And i have a snap on scanner. Everything reads the way it should.... i dont know anymore
Old 08-14-2004, 06:55 PM
twdz28 twdz28 is offline
checked fuel pressure yet???
Old 08-14-2004, 07:05 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
ur cat is clogges....it should b 100 degrees difference between the front and the back of the cat...
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 08-14-2004, 07:24 PM
lol smartass
Old 08-14-2004, 07:25 PM
clogged** be**
Old 08-14-2004, 07:26 PM
korndogg's Avatar
ok mr grammar
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 08-14-2004, 07:35 PM
hehe thank ya mr korndogg
Old 08-14-2004, 08:23 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
hooked on phonics worked for me...
*Better power-to-weight ratio than a C6 corvette*
Old 08-14-2004, 08:25 PM
it worked for all of us!! yay
Old 08-15-2004, 12:31 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Make sure your plugs wires are going to the right cylinders since you changed your opti. Huge power loss like that usually means you have a plug wire messed up somewhere.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-15-2004, 09:12 AM
well. it was running ok after i changed the opti. and last night i was driving home. And the car almost stalled. it wont rev past 3000 and wont go past 10 mph.. even with it floored. I opened the hood and the exuast was so hot the entire engine compartment was lit up. i checked it with my temp light.. but it only goes up to 1300F. COuld it be a fuel pump? maybe all thoes problems ive been having are the fuel pump. Before this happened. I noticed that around 4500-6000 the power droped off alot. And that from 50% throttle and 100% there was really no power. Might even have more acceleration at 50%. Still no engine light
Old 08-15-2004, 09:15 AM
Oh and. I try and floor it. the engine sounds really different. it revs really slow. and is more quiet then before
Old 08-15-2004, 10:31 AM
i checked the fuel pressure... i dont know if im doing it right though. I hooked up the tester .. to the right spot i think.. it screws into the threads fine... but when its running or when i 1st turn it on the gauge dosent move.. even when i rev it. it dosent do anything.. almost like its not even hooked up...
