Old 08-12-2004, 07:16 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Question Questions?
My windshield wipers wont go faster then low speed, I figure I need to get a new wiper motor. Where can I pick one up? Also I have to install a speedo gear how is it done and can i pick one up for 3.73 gears at the local auto parts shop?
Thank you for help.
Old 08-12-2004, 07:25 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Speedo gear to adjust for 3.73's will not be at your local parts store. Give Steeda, Latemod, and many others a call and they will take care of you.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-13-2004, 09:52 AM
andrewespo's Avatar
Re: Questions?
Where can I find a new windshield wiper motor?
Old 08-13-2004, 04:45 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
junkyard for the motor.
installing a speedo gear is easy... just take the 8mm bolt out where the speed sensor hooks to the trans, take out the speed sensor. use a screwdriver to pry the retaining clip out of the stock gear. replace the gear and retaining clip and reinstert the speed sensor, and replace the bolt. and your'e done.
the speed sensor is located near the back of the transmission, near the crossmember. there's a half-inch thick cable (speedo cable) leading to it and a small wiring harness.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 08-16-2004, 10:47 PM
wildstringer's Avatar
wildstringer wildstringer is offline
if you have delay on your wipers it may not be the motor . i mean dont rule out the motor but my ford truck had a delay box under the dash that was bad . im not sure if the mustangs do but i seem to remember seeing unthe dash of my mustang . drivers side close to the door small black box about 2x3 . it should be bolted to the metal rail at the bottom of the dash
Old 08-20-2004, 08:32 AM
SN95GT50 SN95GT50 is offline
Re: Questions?
Yes, speedo gears are avialable for your 3.73:1 gears, but, don't expect it to last long. the teeth tend to get chewed up pretty quickly.
SN95GT50
Old 08-20-2004, 01:08 PM
andrewespo's Avatar
Okay my speedo gear came in. I drove the car up onto my ramps and got under the car. Took the bolt out pulled the speedo sensor, once it came out tranmission fluid steadly poured out. I quickly took the speedo gear off and put the new one on, by this time a good amount came out maybe 1/2 quart. Im wondering if I can start the car with the lowered trans fluid. Also Im thinking I should change all the fluid now, how can I drain it and were do I add it? (P.S. Some good trans fluid choices.)
Thx for help.
Old 08-20-2004, 01:16 PM
Re: Questions?
Not sure what year you have and manual vs auto.
On the T-5 tranny the drain and fill plugs are on the passenger side. Remove then with an allan or torx. Stating the obvious but fill on top, drain towards bottom. Just fill till it starts coming out the fill hole.
To add you either have to pump it into the hole or remove the shifter and pour into the top.
SN95GT50
Old 08-20-2004, 01:57 PM
andrewespo's Avatar
Sorry about not giving specs but its a 88 GT manual. Alright so ill drain it on the passenger side then take clutch off and pour in threw their. Also I changed the speedo gear but thats not the problem with the speedometer not running. Any ideas on what it might be. Is it normal for the trans fluid to come out where the speedo sensor pulls out?
Old 08-20-2004, 02:04 PM
Re: Questions?
You will remove the shifter to put in the tranny fluid, not the clutch.
Not sure in the speedo gear, but, it does sound reasonable.
I would suggest posting on the Corral www.corral.net forums, they can probably answer that question real quick.
SN95GT50
