Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 08-08-2004, 11:44 AM
eclipsefan98 eclipsefan98 is offline
Send a message via AIM to eclipsefan98
Help with V8 mods...
Things are pretty slow around here, so can you guys give me an opinion? what are some mods i can do on my Malibu's 406 ci engine. i already have:
headers
full 3" exhaust (no cats)
high compression pistons
mild cam
no a/c, heater
750 series carb
bored 0.30"
any other ideas?
-1996 Eagle Talon
CAI, reprogramed ECU, NGK plugs, and ported head
-1972 Malibu
Mods: 409ci small block replaced the 6 cyl., posi. rear end, low gear ratios, TH350 trans., high comp. pistons, mild cam, no a/c, heater
Old 08-08-2004, 02:21 PM
landyacht's Avatar
landyacht landyacht is offline
Have you thought about a light-weight and stronger drive shaft or a better rear end ie. better gears?
A turbocharger comes to mind aswell... just a few thoughts!
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 08-08-2004, 02:25 PM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
shift kit
2500 stall torque converter
3:73 rear gears
LSD
***********TIRES***************
seriously I think drivetrain mods are the best ones if you going to keep your car in a stock form. It makes the car totally different to drive.
Old 08-08-2004, 03:19 PM
Robs71Nova's Avatar
Robs71Nova Robs71Nova is offline
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
Headwork, better cam, roller rockers, better intake possibly a high rise, MSD coil/box, shiftkit, depending on your cam around a 3k stall, new gears, locker for Posi, traction bars, better tires,drag shocks, maybe some sub frame connectores (wont really make you go faster but will help stability) and depending on how streetable you want it to be, start with the weight reductions. Typicalls 406's are very strong motors so im thinking that if you put a better cam in there its gonna wake the motor up. It all depends on how much you want to actually drive the car.
Rob
Old 08-08-2004, 05:15 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Definetly a new intake manifold will been nice with everything else you have. Then torque convertor, gears, head work.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-09-2004, 10:18 AM
Re: Help with V8 mods...
i forgot to mention that i have a 2500 stall converter, B+M shifter, shift kit, positraction rear, 3.73:1 diff, line lock (just got it). i dont want to dump too much more money into it because im looking for an import to give the full turbo treatment. how do i post pics because i have some of it at the drag way? thanks for all the ideas!
-1996 Eagle Talon
-1972 Malibu
Old 08-09-2004, 01:24 PM
Banned
I think you just answered your own question then
I think the work on your Nova is completed if your going to buy another car to modify.
Old 08-09-2004, 08:47 PM
Bluetrack's Avatar
Bluetrack Bluetrack is offline
Send a message via AIM to Bluetrack
Definantly would go with a new gear, I heard its most horsepower for your $. MSD 6A or AL Ignition for the cam and hear work..and of course, the gear drive timing..no real power gain from that, but it sounds nice.
Its not about being 'fast' its about being fast for what it is, And i accomplished that much.
Wins: '95 240sx se, 91 CRX hf, 00 Civic, '92 Saturn SL1, 89 Corrola '94 SL1, '95 contour.
Loses: '92 Accord, 94 Camaro, '94 sc2, everything else
DONT RIP IT TILL YOU RACED IT.
