Old 08-03-2004, 08:29 PM
eillob's Avatar
eillob eillob is offline
Raced an SRT-4 at the track last week
I finally made it to the track last Tuesday an it was ridiculously packed. The weather here has been pretty crappy and last Tuesday was perfect. So everyone and there brother was there. I only got to make one pass. As long as the line was I wasn't about to wait twice. Finally got to the starting line and there was a new silver neon SRT-4 next to me. Other than obvious exhaust work I assume it was stock, Im not sure because I never talked to the guy.
Off the line I had a little wheel hop, I came off the clutch a little to fast so he had me by a few feet. But after 2nd gear I caught him and walked him. At the end of the race I had him by half a car maybe. I gotta give them some respect I had no idea they were that fast. I ran a 13.7@ 106.43 He ran a 14.3@ 99.77
I'm a little disappointed in my time I was expecting better with the latest mods. I guess that shows ya gotta get the power to the ground. Well control arms are gonna be my next mods. Maybe them and a set of slicks will get me some better time.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 08-03-2004, 08:41 PM
90Stangjc 90Stangjc is offline
Wow. 106 mph. You should be turning deeeeeeep 13's. No?
1999 Camaro Z28 M6- Aftermarket mods- LS6 Intake, Chip
Home mods - Ram Air mod, !CAGS
FACTORY FREAK BIOTCH!
Old 08-03-2004, 08:47 PM
eillob's Avatar
Re: Raced an SRT-4 at the track last week
Your right, thats my point I've got the power to do it but I gotta get it planted. Stock control arms don't help.
Old 08-03-2004, 11:39 PM
SuperstreetSVT SuperstreetSVT is offline
Send a message via AIM to SuperstreetSVT
that conversion is a Vette, Viper, and Camaro killer, im a ford guy myself but i think that more aftermarket companies need to offer more aftermarket performance then just john lingenfelter.But that conversion is definitly awesome, but i think the nitrious needs to go, american muscle dont need steroids.
Old 08-08-2004, 09:49 PM
augustorm augustorm is offline
Re: Re: Raced an SRT-4 at the track last week
Steeda has some very nice arms (the new aluminum ones) for you...nicely priced....should help...and I am very suprised that with the 100 shot he stayed that close....educate me....what do those neons have in them?
'03 Stang V-6: Bored/Stroked(4.2L), Forged Crank, Wiseco Pistons, I-beam Rods, Crower Cam, Port/Pol Heads & Intakes, Radius valve job, Titanium valve springs, Ram air, NX wet (100 shot), Fluidyne radiator, JBA headers, Mac H-pipe, Borla side exit, Aluminum Shaft, Steeda race T-56, Truloc, 3:73 gears, Triax shifter. Tubular K-member, Steeda C/C plates, Steeda strut tower brace, Ken Brown shock tower brace, Steeda G-trac bar, Subframe connectors, Steeda 5-link, Eibach Prokit, Tokico Illuminas.
Old 08-08-2004, 10:11 PM
eillob's Avatar
Thanks for the info on the control arms. I think found a place online to get the uppers and lowers in one kit.
Getting back to your question. What makes the SRT-4 so leathal is its power to weight ratio. The car comes with a turbo charged 215hp 4cyl. Thats about what a stock 95 GT comes with so its not a lot of hp. BUT the neon is only 2880 lbs. So its about 600lbs lighter than the GT. Here are some specs
http://www.allpar.com/neon/neon-srt-4.html
This race won't be nearly this close next time.
Old 08-08-2004, 10:22 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
What was your 60 foot time?
Please tell me your nitrous was off, because that combo should be able to get over 105 without it.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 08-08-2004, 10:56 PM
eillob's Avatar
60ft time was 2.306
1/8 mile was 9.163
This is the first time I've been to the track with the computer conversion and the nitrous. My plan was to make one pass without the juice and a second with it. But because of the crappy launch I got I hit the juice in second gear to take the lead, after that it was strait motor. If I can get my car to hook up on the line my times will be much improved.
Old 08-09-2004, 10:32 PM
351wStang's Avatar
351wStang 351wStang is offline
I'd suggest adjustable uppers and lift bars instead of lowers.
1969 Cougar
357w & TKO - 475hp
Old 08-09-2004, 10:35 PM
eillob's Avatar
Whats the advantage?
Old 08-10-2004, 11:51 AM
351wStang's Avatar
Stiffer launch, plants the rear tires a little better or harder than control arms and I have found atleast on the car I put lift bars on they did a whole lot better at preventing wheel hop then the control arms. http://www.racerwalsh.com/suspension.htm These are pretty nice here, scroll down close to the bottom of the page and see what you think.
Also the adjustable uppers will allow you to play around with pinion angle to get the best power to the ground.
1969 Cougar
357w & TKO - 475hp
Old 08-10-2004, 01:58 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
do you have to change your rear springs when you install those lift bars? that would make sense to me....
i understand about how the correct pinion angle prevents driveline vibration by keeping the u-joints in phase. but how does playing with it improve your power to the ground?
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 08-12-2004, 07:06 PM
burly94gt burly94gt is offline
its about time you went to the track...you talked to me about going atleast 3months ago... procrastinator
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 08-12-2004, 07:22 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Lift bars are great with street tires. I would how ever not use them wit DR's and especially not slicks. They are way to hard on the car with slicks or DR's when it is just not needed.
The good cheap all around set-up is solid lowers and adjustable uppers. The upper adjustable give you enough adjustment to change your pinion angle that with a decent modded motor set-up you can preload it enough.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-12-2004, 09:39 PM
eillob's Avatar
Sorry Man but I had to make sure my stuff was right. Ill be going back. I gotta improve that time.
